Old 7th February 2011, 04:49 PM   #21
Zen Mod, You are a blessing to this forum ! I will follow your advise to the letter again many thank's
Old 7th February 2011, 04:55 PM   #22
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
naah ......
there is no need to make me happy ( what already I am , in excessive amount ) ;
go here : FIRST WATT ARTICLES , download them all (print or not ) and read .....
that will make you happy
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 7th February 2011, 09:19 PM   #23
d to the g's Avatar
Originally Posted by Zen Mod View Post
I disagree with this. The lines are too straight.
Old 7th February 2011, 09:36 PM   #24
Zen Mod's Avatar
I give you all rights to make them either curvy ...... or fuzzzzzzzy
Old 8th February 2011, 05:09 AM   #25
How about 4) CL60's Hope this is correct ! Click the image to open in full size. F4 Final Layout.jpg
Old 8th February 2011, 08:56 AM   #26
Zen Mod's Avatar
even if 1 common CL60 is adequate for 400VA toroid , second one can't harm
your call
Old 24th November 2011, 05:44 AM   #27
Dzius is offline Dzius  Poland
Are the 2x18V AC secondaries enough ? We can get lower than 23V after filtering.
Or better to have 2x20V ?
In BA articel Nelson says: " our goal is to have approximately +/- 25 volts on the supply rails. Voltages from 18 to 30 volts are acceptable"
Is the 25 V a little better than 23V in the F4 ?
Old 24th November 2011, 08:15 AM   #28
Zen Mod's Avatar
it doesn't make much difference , because most speakers are current hungry , so few volts can't change much
reason for discrepancy is simple - say that 18Vac is industry standard , same as 24Vdc is industry standard
these two are the "same" when PSU isn't heavy loaded ,as it certanily is in A class amp duty
so - just sort of contextual talk
FS: Conrad Heatsinks;.... 'PASS' B1 boards w/JFETS;...... F4 AMP & PSU boards cowboy99 Swap Meet 5 25th August 2009 02:39 AM
Dead PSU.. help needed Havoc08 Everything Else 4 22nd February 2009 03:26 PM
PSU Help Needed ardo Power Supplies 4 26th June 2006 05:15 PM
Help needed PSU designing k1jroth Power Supplies 13 6th May 2005 08:21 PM
help needed with psu for TDA2050V TheRockLobster Chip Amps 4 3rd February 2004 06:57 PM
Page generated in 0.09214 seconds (75.37% PHP - 24.63% MySQL) with 11 queries
