Old 1st February 2011, 02:51 AM   #1
Unhappy DIY Aleph 2 Monoblocks
Hello everyone,
One of my monoblocks suffered a minor failure with one of the supply caps.
Apparently one of the connections worked it's way loose on the cap terminals and caused some arcing which in turn caused tremendous heat to the terminal(s) of one of the 4 33kmf 50V PS cap and physically burned the star ground wire and the terminals of the cap itself. So luckly no damage to the output stage, and infact music was still being produced while the burning smell became evident. In the process of replacing the caps (all 4) I made an effort to replace them exactly to no avail, so I ended up finding 4 NEW 33kmf with higher voltage rating and 95C (instead of 85C original) and closer tolerance. Everything went together perfectly and sounds just a beautiful (Thank you Mr. Pass) and so for the big question - Why is the amp running about 6 deg.F
(142 F) hotter than before and about 9 deg. F hotter than the other unit? Could the bias have drifted because of perhaps a better quality caps? The sinks are pretty hefty. The temp. reading is actually being measured at the direct opposite side (Fin side) of where the IRFP240's are mounted. 5" further down the fin is reading 125 deg F. What is going on here?
Thank for all of the member of DIY.com for this informative site.
jritota
Joe
Old 2nd February 2011, 01:14 AM   #2
Eric is offline Eric  United States
Eric's Avatar
Two quick guesses to answer your question about higher temp with the new caps:
1) newer and better caps have lower ripple voltage than the older caps, thus a more consistent rail voltage than before?
2) newer and better caps have lower ESR (resistance) than the older caps, thus a higher rail voltage than before?
Can you compare the DC voltage on your power supply caps of the two amps?
Eric
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages.
Old 2nd February 2011, 10:43 AM   #3
Formerly Thanh1973
Melon Head's Avatar
Eric
This is exactly what I was thinking
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need."
Old 3rd February 2011, 12:02 AM   #4
Sounds like a good place to start. I don't know why I didn't think of that first.
Will give it a shot as soon as time warrants. Average temp across that bank of sinks is 135 F. Is it time for some forced air in the case? Phoey!! I hope not. As you can see the cases are huge, innards are well spaced apart and the back plate of the sinks are 5/8" thick, giving good heat distribution throughout the whole sink area. Any more opinions?
Thanks so much Eric
Joe
Joe
Old 3rd February 2011, 09:49 AM   #5
h_a is offline h_a  Europe
h_a's Avatar
In an amp with a constant current source ESR of the caps does not play much of a role; better check bias
If bias and rails are the same, heat transfer of fets to sinks is different for some reason.
Hannes
AX100 100W Aleph-X Monoblocks gl Pass Labs 634 26th January 2012 12:46 PM
Aleph-X monoblocks finished. steenoe Pass Labs 147 3rd September 2008 03:41 AM
Aleph 3 monoblocks for sale cowanrg Swap Meet 4 17th April 2007 04:37 AM
Page generated in 0.07462 seconds (80.06% PHP - 19.94% MySQL) with 11 queries
