Help wanted,aleph (cl) ono problem (long)
Old 5th February 2011, 11:21 PM   #11
jazz is offline jazz  Netherlands
So I changed the led and it seems to work again. Thanks guys! I changed the led first and after that the resistor, next i soldered the resistor to ground. It seems to be stable now but i'm gonna do some more tests before I change the other channel as well.
What bugs me still, is the question what actually happened. I mean i don't know this failure mode and assume that if a led emits light, it works. I would like to know if this is a known failure behaviour for a led? Now that i calculated the differences for connection to ground versus plus rail, i got a hint. But why doesn't the resistor fail and/or shows signs of distress at twice it's rated dissipation before the led dying?
I mean like I suspected the fet's and transistors first, and changed them straight away. First the output fets and source resistors. check and close up. next output fets, source resistors, the bias pot and reflow/solder all components. check and close up, next output fets, source resistors, bias pot, transistors and fet in the vbe/bias (how should it be named). check and close up. Stop and ask for help.
Channel to channel measurement, bias and voltage readings done during the checks but started measuring longer and longer and play with temperature. so I learned to look for the moment of run away and be ready to pull the plug.
Is this what you would have done when fault finding?
Thanks for the help and thinking with me. I think i can finish it up now, but I'm still bugged about not finding the obvious problem earlier.
Joris
oh, what a beautifull day
I wanna go out and play!
Old 6th February 2011, 07:40 AM   #12
nar is offline nar
nar's Avatar
It's likely that the resistor hasn't reach yet the rated dissipation factor, that's all
Led is semicon as the transistors are, in a way. I think it could be damaged whilst you saw it having 10V or more across the pins before "pulling ou the plug".
I todl you, lol, change all the fets and led lol
Joris
The best thing to do is : th next time you set up a board, don't reverse polarities ... or be ready to bug check and find the culprit(s)
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 18th September 2012, 06:11 AM   #13
kamis is offline kamis  Serbia
I kindly ask X-Ono designer to explain the way of R-5 connection in the real, manufactured Pass-Xono.
Old 18th September 2012, 07:16 AM   #14
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
irrelevant
just calculate it's value to feed LED with 3-5mA
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 18th September 2012, 08:01 AM   #15
Originally Posted by Zen Mod View Post
irrelevant
LED voltage is important for CCS , not current. I know how to solve problem, but I just wish to know how Mr. Colburn connected R5 resistor in the original circuit.
BTW, how about DC servo for X-Ono second stage ?
Old 18th September 2012, 08:06 AM   #16
Zen Mod's Avatar
whatever you say......
put BF245A CCS instead resistor
LED voltage will not change wherever you put (appropriately sized) resistor - gnd , +Ub , +3MV
regarding servo ..... you said you're capable of solving problems
edit:
btw , in original XONO that resistor is connected to GND
for putting it to 3MV , you'll need resistor string of ~ 600 MOhm , 30KW
Old 24th October 2014, 06:07 PM   #17
Do you suggest using CCS as an improvement ? Better power supply rejection for LED?
Old 24th October 2014, 06:54 PM   #18
Zen Mod's Avatar
well , yes
will you hear difference , in this case , is dubious
Help wanted,aleph (cl) ono problem (long)Hide this!Advertise here!
Coupling Caps in Aleph Ono/XOno and Aleph X0 rsbay Pass Labs 12 23rd November 2006 08:05 PM
Aleph-Ono/X-Ono mach.88 Pass Labs 8 10th April 2006 06:28 PM
Wanted: Pass Ono Boards Onvinyl Swap Meet 4 24th April 2005 04:40 AM
CL 60 thermistor For Aleph 2 jeclk Pass Labs 13 26th February 2003 10:30 AM
ALEPH ONO Jens Pass Labs 4 24th March 2002 09:27 PM
