Old 28th January 2011, 07:35 AM   #1
Tyimo is offline Tyimo  Hungary
Smile Capacitor questions
Hi!
I would like to ask some questions:
1. Sometimes I see in voltage divider mosfet bias circuit a
capacitor connected between the middlepoint of the voltage divider to the ground. Sometimes not.
A, Is this cap really necessary or not??
B, Should be ELKO or foil cap?
C, Is there any rule for calculating such a capacitor's value?
2. Sometimes I see "Accelerator" capacitor on the amplifier PCB, in the input of V+ to ground. Sometimes not.
Sometimes it is a few hundred uF ELKO or a couple of nF fouil cap.
3. This is an evergreen question :-)
What kind of input cap is good?
In some cases I see ELKO in the input, but sometimes foil cap.
Which is better?
Greets:
Tyimo
Old 28th January 2011, 08:18 PM   #2
Nobody can answer?!?
I cann't believe....
Old 28th January 2011, 08:23 PM   #3
The one and only
Nelson Pass's Avatar
You must have some patience. Most of the wise guys
around here are old and slow.
Old 29th January 2011, 07:09 AM   #4
Yes, Master!
Maybe you could best respond?
Greets:
Tyimo
Old 29th January 2011, 09:02 AM   #5
Formerly Thanh1973
Melon Head's Avatar
I will answer 3.
No cap is better than film is better than electrolytic
There is more to it than that but i don't want to ramble on
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need."
Old 29th January 2011, 09:06 AM   #6
Tripmaster's Avatar
Originally Posted by Melon Head View Post
I will answer 3.
37...not that old?
Richard
My photostream: http://www.flickr.com/photos/59839778@N04/
Old 29th January 2011, 09:24 AM   #7
At least a third of Members are asleep at any time.
At least a third will be doing something else at any time.
Of the remainder, how many would you expect to be online when you post a question?
regards Andrew T.
Old 29th January 2011, 07:13 PM   #8
I wrote my reasking question after that I saw there was already more than 77 views....
But I am patient.
Old 29th January 2011, 07:15 PM   #9
It is too simple answer.
Look at Mr. Pass's designs! He also use many time ELKO as input cap.
Old 29th January 2011, 08:57 PM   #10
Gordy is offline Gordy  United Kingdom
Originally Posted by Tyimo View Post
Hi!
If the voltage divider then feeds a large value resistor to the bias point (mosfet gate), then the answer is usually 'yes, a capacitor is sensible'.
Working with the voltage divider resistor, the capacitor forms a RC low pass filter to smooth the bias voltage. Use an electrolytic.
Amp capacitor questions. (2) Artie Car Audio 6 26th April 2009 01:02 PM
questions on Capacitor rating? nina Chip Amps 11 3rd April 2006 01:01 AM
More capacitor questions.. guitargully Solid State 5 3rd January 2004 06:17 AM
Capacitor questions Skankadellic Multi-Way 7 8th September 2003 10:06 AM
Page generated in 0.11198 seconds (79.11% PHP - 20.89% MySQL) with 11 queries
