Another way to paradise ?
Old 25th July 2003, 09:00 PM   #1
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Talking Another way to paradise ?
Today in the train while trying to understand the susy for the first time, I got some idea...
Just quick and dirty:
At the negative inputs of the op amps the clean part of the signal is much more attenuated than the distortion part.
Any good ?
Output impedance of the signal source is 0 ohm.
Old 28th July 2003, 08:48 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The distortion will pass through V3 to the positive input,
and be reamplified, won't it?
Old 7th August 2003, 11:38 PM   #3
Bernhard's Avatar
Yes but when I look at the mono susy amp, I can see a similar positive feedback path from amp's left output - feedback to other side resistor - right side noninverting opamp input- input series resistor- signal source - input series resistor- left side noninverting opamp input
Old 8th August 2003, 11:19 PM   #4
Bernhard's Avatar
I connected R22 to the noninverting input of x1 and other side same thing.
Then played with values to get full output swing @ 2V input.
Added a 5kHz sine source with 10Vpp and a 10ohm series resistor and connected that parallel to the load.
This is my distortion
With PSU switched off in the sim this gives a 5kHz 4.5Vpp sine across the load.
With PSU switched on and inputs shorted the 5kHz sine is reduced to 50mV.
-40dB ?
The 5kHz sine across the 1k input resistors is 160yV.
What does this want to tell me
It is also very nice to see in the sim how the opamp output (if a 10ohm is added on the opamp output) works against the external distortion
Another way to paradise ?Hide this!Advertise here!
FS: DIY Paradise USB Monica 3 (assembled) hubsand Swap Meet 1 24th November 2008 09:38 PM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 03:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 07:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 05:37 AM
anyone tried the diy paradise simple el84 pp RockysDad Tubes / Valves 6 11th April 2005 05:19 AM
Copyright ©1999-2017 diyAudio
