B1 preamp build thread
Old 20th February 2013, 04:38 PM   #51
bnorrish is offline bnorrish  United States
bnorrish's Avatar
I would not say lazy. I find compiling BOM very tedious and time consuming. Here is one I have - unverified . Use it as a starting point and check. Also, It is for the Mezermize PCB from the DIYAudio store.
Old 5th April 2013, 09:14 PM   #52
Rixsta is offline Rixsta  United Kingdom
Originally Posted by KatieandDad View Post
That is just being incredibly lazy.
haha, it is but also sometimes when your new to it it is very hard to find the parts and its nice to have a reference to go by on by someone who knows what they are talking about
www.rikibuckingham.com...
Old 5th April 2013, 09:54 PM   #53
Take Stranded wire for instance, i have absolutely no idea where to start in this list for appropriate wire for F5 or B1
Buy stranded online from RS Components
Old 6th April 2013, 12:58 AM   #54
bnorrish's Avatar
18 awg stranded hookup wire is what I used mostly except.16 awg stranded hookup wire PSU connections. Get a bunch of different colors and create your own color standard. There is a vendor on here Apexjr that sells Teflon hookup wire.
Old 6th April 2013, 08:15 AM   #55
R.I.P.
I use insulated 0.6mm diameter solid core copper.
It would be cheaper to use the insulated ~0.5mm diameter cores from CAT5, but it is a lot of work to separate and straighten.
regards Andrew T.
Old 6th April 2013, 08:52 AM   #56
R.I.P.
If you require ready made twisted pairs then CAT5 is worth the effort to strip off the outer cover.
repost of incomplete post due to delay in the Forum showing my post.
regards Andrew T.
Old 6th April 2013, 11:26 PM   #57
6L6 is offline 6L6  United States
6L6's Avatar
For signal wiring inside the chassis, thinner is better.
Andrew's suggestion of CAT5 is spot on - it's a bit of work, but very worth it.
Old 7th April 2013, 10:22 PM   #58
Lovely! your suggestions most helpful, i heard some time ago Ethernet cable was a good choice for small signal audio so shall use that for the runs from
4x RCA > Rotary Switch > B1
the 16-18awg wire sounds good for higher power connections, also in the past have just used mains wire.
Old 15th October 2013, 08:52 AM   #59
generg is offline generg  Germany
generg's Avatar
So the Axon 10uF caps Nelson uses in his B1 (as far as I saw in the pictures of the open case) have not a very good recommendation in the capacitor test at
Humble Homemade Hifi
I tried them and they do a special sound, I like them very much! Concurrents were Clarity Cap ESA, Obbligato old ones, Cornel Dubilier KP and some other.
Well chosen Nelson!
and the First Wtt is......a really First Class PSS Idea
Old 21st January 2014, 02:19 PM   #60
hartbigsky is offline hartbigsky  United States
Default B1 power supply
Hi 6L6,
Peter Daniel does not have any universal power supply boards now. Will the PassDIY universal power supply work in this build? Thanks!
Steve
B1 preamp build threadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
Help diagnosing B1 Build (newbie) dasfreak Pass Labs 4 30th November 2010 01:56 AM
help with b1 + gainclone build crappyjones123 Pass Labs 4 25th June 2009 09:56 PM
B1 Preamp - Help Me! Professor smith Pass Labs 173 21st October 2008 03:55 PM
