B1 preamp build thread
Old 1st May 2018, 12:27 PM   #481
marconi118 is offline marconi118  Germany
yes this bf862 headamp seems great!
can I omit the input gain stage, as I only need the a buffer?
what is the minimum output load impedance 16 or 8 ohm?
Old 1st May 2018, 01:12 PM   #482
6L6 is offline 6L6  United States
6L6's Avatar
No, you'll need the entire circuit for proper operation.
Old 2nd May 2018, 12:15 PM   #483
Dennis Hui is offline Dennis Hui  Canada
Looks like BF862 is EOL.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 15th May 2018, 01:12 PM   #484
Mixi is offline Mixi  Austria
The manual says to use 1/4 W RN55D resistors. Thing is that the RN55D only seem to come in 1/8 W. RN65D would be rated at 1/4W. Which ones should i use?
Thanks!
Old 15th May 2018, 01:48 PM   #485
WalterW is offline WalterW  Netherlands
RN55D is 1/8W military spec. It is in real life 1/4W or even 400mW resistor. So you can use those. They are basically the same as CMF55, I always choose the cheapest ones at Mouser, sometimes the CMF55 sometimes the RN55
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 16th May 2018, 08:47 AM   #486
now the CMF55 seem to be rated at 1/2 watt - although i also saw a spec sheet rating them at 1/4 watt. i guess it's never a problem if a resistor can dissipate more W, right?
me learning a lot about resistors these days :-)
on a different note i found a nice cap for C1. i was looking for a very small can with as much uF as possible as I'm trying to fit this in a rather small enclosure. i think for the size (25mm dia, 30mm height) this one with 12ooo uF is a good fit: Cornell Dubilier 381LX
Old 16th May 2018, 05:29 PM   #487
Eslheadphone is online now Eslheadphone  United States
The CMF series are non-magnetic. I use them in most of my builds. The rated power dissapation of resistor will vary depending on the ambient temperature. The data sheet tells the whole story. Depending on the resistance, it is sometimes cheaper to buy the CMF series.
Old 16th May 2018, 07:48 PM   #488
The CMF60 can cost Less than the CMF55 . I shop the prices at Digikey and Mouser
Old 23rd May 2018, 09:55 AM   #489
adason is offline adason  United States
adason's Avatar
Hi 6L6, i got simple question. Has anyone build B1 with p channel jfets? I suppose one would just flip power supply and electrolytic caps, right?
Old 23rd May 2018, 11:24 AM   #490
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
considering how scarce they are , I hope you didn't ask for Toshina P JFets
yes , absolutely doable
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
B1 preamp build threadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
Help diagnosing B1 Build (newbie) dasfreak Pass Labs 4 30th November 2010 01:56 AM
help with b1 + gainclone build crappyjones123 Pass Labs 4 25th June 2009 09:56 PM
B1 Preamp - Help Me! Professor smith Pass Labs 173 21st October 2008 03:55 PM
