B1 preamp build thread - Page 4 - diyAudio
Old 15th October 2012, 10:17 PM   #31
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by JRKO View Post
Do I wire all the inputs to the switch and use only one of the B1 boards inputs to receive the 6 switched inputs?
Yes.
Also is it possible to have get 2 outputs from the B1 by wiring to both the boards inputs?
I think you mean wiring to the outputs. Just run the output from the B1 pcb to 2 output jacks.
Old 15th October 2012, 10:18 PM   #32
6L6's Avatar
Originally Posted by José Humberto View Post
Is this the PSU? I can´t open the file.
Have it enough filtering?
Yes, that PSU will be fine before the B1 PCB. There is enough filtering on the B1 PCB to use an unregulated supply, so a regulated one like the link you show will be much quieter!
Old 15th October 2012, 10:32 PM   #33
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by 6L6 View Post
Yes.
I think you should maybe also have double output series cap/resistor
Old 15th October 2012, 10:39 PM   #34
6L6's Avatar
That seems like a good suggestion.
Old 16th October 2012, 07:47 AM   #35
JRKO's Avatar
Send a message via AIM to JRKO
Tnx 6L6. So I wire 2x pair of phono sockets for the output. Does it matter if I do that series or parallel?
Hi tinitus - does that mean double up some of the parts from the B1 circuit or a little set on the output jack terminals?
I was thinking I could run 2x pair of wires from the input selector and run both sections of the B1 at the same time giving me 2x identical outputs. I think I'd need to do something fancy with the volume wiring thou. Was that dumb?
If I'm not making noise, I'm making something to make noise
Old 16th October 2012, 08:56 PM   #36
6L6's Avatar
I think he means to have a C x01, R x04 and R x05 on each output jack.
(Just to clarify, "C x01" means either C 101 or C201, the first digit is just the separator for the L or R channel)
Old 18th November 2012, 11:51 PM   #37
6L6, what a great job on build and info, both. Is it possible for you shed any light at all on the chassis you used? I remember you said it came to you thru a friend. It really appeals to me, and I'd like to be a copycat!
Best -
Jeff
Old 19th November 2012, 01:21 AM   #38
6L6's Avatar
I believe it was from a long-gone place called 'diy hifi enclosures' or something like that...
I'm sure there is something similar available, but the exact one? Probably not.
Old 17th December 2012, 05:42 AM   #39
Would it make too much of a difference if i used the following capacitor for C101 and C 201 instead of the 10uF as mentioned in the B1 buffer article.
AXON-73703 11uF / 250VDC, True Cap,* 22mmD x* 38mmL
Nikhil
Old 18th December 2012, 06:29 PM   #40
6L6's Avatar
Sorry that there wasn't a more timely reply...
Those caps will be fine.
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
Help diagnosing B1 Build (newbie) dasfreak Pass Labs 4 30th November 2010 01:56 AM
help with b1 + gainclone build crappyjones123 Pass Labs 4 25th June 2009 09:56 PM
B1 Preamp - Help Me! Professor smith Pass Labs 173 21st October 2008 03:55 PM
Copyright ©1999-2017 diyAudio
