B1 preamp build thread
Old 26th November 2017, 01:04 PM   #341
OlegSh is offline OlegSh
Originally Posted by stefanhgm View Post
Does anyone know where to get an extending rod for the alps poti? Or is the local hardware store the best place to look?
I just bought 6mm diameter brass rod on 'bay. To join it with the pot shaft look for the flexible shaft couplers (for 6mm diameter shafts).
Oleg
Old 26th November 2017, 11:40 PM   #342
thegoldenear is offline thegoldenear  Australia
thegoldenear's Avatar
Hey everyone,
can I use the Vout of my DCB1 Board to power the I-Select board? If so, is there still need to put the caps C1/C2 and IC1 and the Diodes on the I-Select board?
Extension Shaft for Volume Control Potentiometer 300B | eBay
tweaker.......
Old 27th November 2017, 05:33 PM   #343
stefanhgm is offline stefanhgm
Thank you very much. What about my second question, is it possible to power the I-Select board via Vout of the DCB1?
Old 11th January 2018, 06:25 PM   #344
folkdeath95 is offline folkdeath95  France
folkdeath95's Avatar
I have a doubt concerning the wiring of the pot.
My Khozmo attenuator has the following marking: IN-OUT-GND.
I think to solder:
IN to CW
OUT to W
GND to CCW
Is it right?
Petite Onken/Altec 414-8B+Altec 808-8B/GPA aluminium diaphragm/Altec 811; Firstwatt Aleph J Clone; Firstwatt B1 clone; Technics SP10; Sphinx Myth9 MkII
Old 11th January 2018, 07:05 PM   #345
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
it seems ok
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th January 2018, 07:36 AM   #346
R.I.P.
I think to solder:
IN to CW
OUT to W
GND to CCW
Is it right?
Please remember that the input is a TWO (2) wire connection. Input connects to CW and to CCW
The output is also a TWO wire connection. Output comes from W and CCW.
Do not break any of those 4 wires. All are needed to pass the signal from the source to the receiver.
regards Andrew T.
Old 12th January 2018, 01:58 PM   #347
Originally Posted by Zen Mod View Post
it seems ok
Thanks.
But those connections are made on the PCB, no?
I just wanted to find the relation betwwen what is written on the PCB (C-CC-CCW) and what is written on my attenuator (IN-OUT-GND) to connect it like on the picture below:
Old 13th January 2018, 12:25 PM   #348
I finished my B1 yesterday and began to test it this afternoon.
The problem is I've got a very weak and distorted sound on the right channel.
Do you have any ideas (things to check, measures to make) to solve this?
Thanks.
Old 13th January 2018, 12:59 PM   #349
Zen Mod's Avatar
how , without any detail ?
which iteration , no pictures .......
Old 13th January 2018, 01:21 PM   #350
Sorry.
It's made using the PassDIY boards. Here are some pictures:
The problem I have is that the sound is weak and distorted on the right channel.
Test I've made:
-using an other input: same problem
-inverting left and right channel at the input: problem stays on the right channel
-inverting left and right channel at the output: problem goes on the left channel
-inverting left and right channel on the attenuator: problem stays on the right channel
So I think there's something wrong after the attenuator. I don't know if there's some voltage to check what's wrong (when working on my Pearl 2, I found a schematic with some voltages but I can't find such a thing for the B1).
B1 preamp build threadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
Help diagnosing B1 Build (newbie) dasfreak Pass Labs 4 30th November 2010 01:56 AM
help with b1 + gainclone build crappyjones123 Pass Labs 4 25th June 2009 09:56 PM
B1 Preamp - Help Me! Professor smith Pass Labs 173 21st October 2008 03:55 PM
