B1 preamp build thread - Page 3 - diyAudio
Old 4th July 2012, 04:37 AM   #21
6L6 is offline 6L6  United States
6L6's Avatar
Looks good!
Where did you get the rotary switches for the selector and attenuator?
Old 4th July 2012, 04:48 AM   #22
PKI is offline PKI  United States
PKI's Avatar
partsconnexion.com. I experimented with log volume control, but it was not worth it, log is useful only after 10-11 o'clock.
This is how it started:
Old 4th July 2012, 04:54 AM   #23
PKI's Avatar
Compact in size, but not in sound :-)
Old 4th July 2012, 03:31 PM   #24
formula 22's Avatar
Guys, where is the schematic (circuit) of this preamplifiers?
Thank you
Old 4th July 2012, 04:37 PM   #25
KatieandDad's Avatar
Originally Posted by KatieandDad View Post
The B1 is pretty forgiving with its PSU.
I run mine from a 30VA 9-0-9V into a stock 1A bridge then CRC with 2 x 4700uF LCR caps with 2R2 between them. Reg is a straightforward LM317.
Its actually better than a DCB1 that I am trial building at the moment. I did use Obbligato 10uF Caps though.
The little PCB on the top left is just a Mains Filter that I pinched straight out of a VCR.
The PCB is Home-Brew. Although it is Double Sided there are no tracks on the Upper Surface, just the Ground Plane.
Ever so easy to make at home.
My B1 has evolved with a Salas Shunt Reg.
Old 4th July 2012, 04:43 PM   #26
6L6's Avatar
Here is a link to the article -- http://www.passdiy.com/pdf/B1%20Buffer%20Preamp.pdf
Old 4th July 2012, 04:48 PM   #27
If you wonder where the Salas Shunt Reg PCB came from, it's Home Brew. After talking to Salas he graciously let me use the original artwork for the Mesmorise which I cut off the B1 portion. For some reason my H.B. DCB1 wasn't at all reliable, probably down to a track shorting somewhere. I eventually kept the PSU part and reverted back to my H.B. Pass B1 with the huge Obligattos. Result is pure Nirvana.
Old 13th July 2012, 03:23 AM   #28
PKI's Avatar
I've changed 10uf capacitors in my B1: ClarityCap ESA --> WIMA MKP4 250v. I can tell that they are quite good. Very neutral, very! They really sound good! They are cheap (can be found at $15 pair shipped) and fits perfectly, leading spacing exactly as on the PCB. So, if you do not to spend much on Audio caps -- these are highly recommended.
Old 12th October 2012, 11:09 AM   #29
JRKO's Avatar
Send a message via AIM to JRKO
Thanks for the build process 6L6. I have a couple of questions thou
I have the same switch as rabaird, a 6-way 2-pole from HifiCollective.
As I understand it the B1 has 2 inputs. I need to use all 6 on the switch. Do I wire all the inputs to the switch and use only one of the B1 boards inputs to receive the 6 switched inputs?
Also is it possible to have get 2 outputs from the B1 by wiring to both the boards inputs? Would help with bi-amping
Many thanks
If I'm not making noise, I'm making something to make noise
Old 12th October 2012, 04:37 PM   #30
Default PSU
Originally Posted by 6L6 View Post
Audio circuit schematic is in this article - http://passdiy.com/pdf/B1%20Buffer%20Preamp.pdf
Audio board for sale here -- DIY Order Form
PSU circuit board - Universal Power supply PCB from Peter Daniel DIY Chip Amplifier Kits, PCB's, Components and Information. This product is not on his website, but email him and he takes care of it quickly. Lots more info on this board here - Universal Power Supply PCB
PSU regulator Schematic - http://cache.national.com/ds/LM/LM117.pdf
Hello guys.
I´m thinking built the B1 too.
Is this the PSU? I can´t open the file.
Have it enough filtering?
Best regards
Jose
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
Help diagnosing B1 Build (newbie) dasfreak Pass Labs 4 30th November 2010 01:56 AM
help with b1 + gainclone build crappyjones123 Pass Labs 4 25th June 2009 09:56 PM
B1 Preamp - Help Me! Professor smith Pass Labs 173 21st October 2008 03:55 PM
Copyright ©1999-2017 diyAudio
