DIY D1 I/V STAGE
DIY D1 I/V STAGE
Old 13th March 2011, 04:35 PM   #21
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
DIY D1 I/V STAGE
for your needs - you need to decrease sum current for regs to - say ~ 60mA max ( increase R1 in both regs to 10 ohms)
there is no need for more of that , if active stage is drawing 20mA
that way - roughly -overall consumption per channel is 60mA x Vdc = 60mA x 1,41 x 30V x2
regarding needed amplitude of output signal
considering that current output of PCM for full blast is +/-1.2mA - just divide your needed p-p amplitude with 2,4mA and you'll get value for R6
this way ( with R6 1K5) , you'll have 3V6pp on output
if you're going to use set of regs for both channels - go for 100mA as programmed current ; in that case R1's must be around 6R5
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th March 2011, 04:53 PM   #22
merlin el mago is offline merlin el mago
merlin el mago's Avatar
So 4Vpp divided 2,4mA = 1k666 for R6 & I will have 2Vrms?
Old 13th March 2011, 07:43 PM   #23
Zen Mod's Avatar
DIY D1 I/V STAGE
math is simple
Old 13th March 2011, 10:07 PM   #24
Thank you ZM
Old 13th March 2011, 10:15 PM   #25
Zen Mod's Avatar
DIY D1 I/V STAGE
you're welcome ;
answers are simple when questions are well constructed .
Old 14th March 2011, 09:22 AM   #26
Originally Posted by Iloveswan View Post
You should raise R2a's value a little bit unless you can accept around 1Vrms output. If you raise R2a's value, you need to change source resistors value accordingly too.
About Mosfet match, it's easy to get a 1% Vgs matched pair from same production batch.
@ZM
So don't need to change R2 as Iloveswan suggested & he do bad calculations 1Vrms instead 1.8Vrms?
Old 14th March 2011, 10:01 AM   #27
Zen Mod's Avatar
DIY D1 I/V STAGE
leave R2 as is
Old 14th March 2011, 10:13 AM   #28
Old 16th March 2011, 05:19 AM   #29
Iloveswan is offline Iloveswan  United States
Originally Posted by merlin el mago View Post
@ZM
Correct. you should change R6 not R2... sorry for typo...
Old 16th March 2011, 10:24 AM   #30
Zen Mod's Avatar
DIY D1 I/V STAGE
naah .......
what's few numbers between friends ......
DIY D1 I/V STAGEHide this!Advertise here!
DIY D1 I/V Stage from Pass Dac PCBs for sale promitheus Swap Meet 102 25th February 2011 09:03 PM
Copyright ©1999-2017 diyAudio
