DIY D1 I/V STAGE
DIY D1 I/V STAGE
Old 13th March 2011, 10:15 AM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
DIY D1 I/V STAGE
can you calculate from this schematic that power consumption of channel is under 1W ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th March 2011, 12:33 PM   #12
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I got it the informtaion I think its 10-20mA per channel.
So 10VA would be minimum.
I will use only 1 tx 2x30VAC 50VA for stereo.
Old 13th March 2011, 02:03 PM   #13
qusp is offline qusp  Australia
qusp's Avatar
yes its much lower than owens d1, where each fet is operating about 130ma
Old 13th March 2011, 02:08 PM   #14
Zen Mod's Avatar
DIY D1 I/V STAGE
well - you asked , and I wrote exact currents on schematic , which you obviously didn't looked .
anyway - power cons. is under 1W/per channel
exact requirement for xformer depends of reg used ;
I know that with regs I usually prefer , 50W will suffice for both channels
in your case , you can probably feed 10 stereo D1's with 50W
Old 13th March 2011, 02:41 PM   #15
I will use Salas Low Voltage Shunt Regulator, I find 1 tx 2x30VAC 60VA can be enough?
Old 13th March 2011, 02:55 PM   #16
Zen Mod's Avatar
DIY D1 I/V STAGE
well - either ask Salas , or post exact schematic here , or post link to it .
Old 13th March 2011, 02:56 PM   #17
Zen Mod's Avatar
DIY D1 I/V STAGE
besides that - you need to know on which DC level is output of PCM1704 , so you'll need to set input of D1 to same level
Old 13th March 2011, 03:12 PM   #18
Originally Posted by Iloveswan View Post
You should raise R2a's value a little bit unless you can accept around 1Vrms output. If you raise R2a's value, you need to change source resistors value accordingly too.
Wich value for R2a (R2b) & wich resistor is source resistor & value needed to get 2Vrms?
Old 13th March 2011, 03:14 PM   #19
The I/V is designed for DAC current output PCM1704, PCM56, etc.
Old 13th March 2011, 03:17 PM   #20
Minimum diff. to work 8-10V Vin-Vout, so for 42.3Vin can regulate 30Vout
Thanks for help.
DIY D1 I/V STAGEHide this!Advertise here!
DIY D1 I/V Stage from Pass Dac PCBs for sale promitheus Swap Meet 102 25th February 2011 09:03 PM
Copyright ©1999-2017 diyAudio
