As a pensioner I am naturally cautious with my money, but over the years have wasted almost as much on 'hi-fi' through ignorance as I have on fly
fishing! It has always been my ambition to own a pair of horn speakers and I now have a partially completed set of Austin A166 (ESR versions), but need something to drive them. There are now very few retail suppliers locally for components and my original intention was to build a Linsley Hood Class A, but I was seduced by the simplicity of the F5 and bought a kit advertised on eBay. I'd like to express my apologies to Mr Pass as I naively assumed that the boards were 'official', but have discovered my mistake on joining diyAUDIO. My problem is the power supply for the monoblock F5s. I bought two toroidals, four bridges and a box of Nippon Chemi Comm KMH 35vdc/15,000uF capacitors and four 55uF motor run capacitors in preparation, but also wasted money on the wrong inductors. Now after browsing hundreds of pages I still feel that I am no closer to understanding the actual requirements of the F5 despite playing with PSUD for hours (JLH originally used a clever stabilized power supply). It has been suggested that the largest capacitor should be second in the CRC network for the power supply and that CLC is better than CRC, but that the first capacitor should have a high ripple tolerance. Andrew(?) suggested that this could be achieved with multiple parallel low value capacitors (e.g. five 1,000uF would have better ripple capacity than a single high ripple 4,700uF capacitor). Inductors should be 2-10.0mH though mains frequency or load do not seem to be discussed in this context. I think that the KMH capacitors have a ripple level at around 3.72 amps and an ESR of 0.028 ohms. Confused? Well I am. In the UK we have mains at 240 vAC and 50 Hz frequency and I think that the F5 draws 1.3amps. I believe that bridge rectifiers generate an erratic saw-tooth pattern that is then smoothed through filtering. PSUD will not allow an inductor straight after the bridge, but I think that any capacitor in this position will be charged in bursts of energy that reflect the load and the mains frequency, which might cause problems for the transformer. In an old post it was suggested that a 4.7uF capacitor across the secondaries could prevent ringing in the transformer, but Steven(?) suggested that it was better to place this across the +/- of the bridge rectifier. Mr Pass simply uses CRC or is it CCRCC, but starts with bleed resistors. Please forgive my ignorance and failure to acknowledge contributors accurately, but what do members recommend as the best possible safe power supply for this amplifier given my purchases and the above. Please do not cite the lovely Irish expression about reaching destinations, which goes something like "... I wouldn't start from here!" |
#2 |
write exact number of caps you have
don't worry - I'm not Irish ...... worse than that
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
build up a mains bulb tester.
This will prevent damage to you or you equipment if you wire up any transformer wires wrongly. It will also provide a lot of protection to the PSU and the zero biased amplifier when you are still new at the game. But, I keep repeating this. Use the bulb tester to power up EVERY new project and EVERY modified project. Do the assembly in stages. Start with the transformer alone. Wire it up as instructed and power it through the bulb. Is all OK? Add on the rectifier. is all OK. add on each rectifier, checking each is OK. ad on just four smoothing caps. One to each rectifier. Is all OK. Start measuring input and output voltages as a final check that all is OK. Understand what you have done so far. You can either add on one channel of F5 or modify the PSU to your final arrangement. But again check in stages. Slow progress is better than burnt components or eyes. What building or test equipment do you have? DMM, scope, soldering iron, "helping hands", solder, magnifying glass?
regards Andrew T. Last edited by AndrewT; 8th January 2011 at 11:01 AM. |
#4 |
andrew
don't complicate things ; man asked general question , not for building tutorial ; that will do good later , not now .
#5 |
My goodness, I have hardly sat down and you are kindly responding!
Zen Mod - I have twenty-four capacitors. AndrewT - thank you for your kindness. I'll be careful, but still do not know quite what additional components I need for an excellent psu. Apologies, if I quoted you out of context. |
#6 |
Andrew - sorry I forgot to answer your question. All I have is a DMM, but I have soldered stuff in the past. The problem is the past goes a long way back!
#7 |
first and most important : you can always count that following Nelson's approach is safe bet
second : you can always do better ( in some things ) but there is possibility that overkill approach will not give any significant gain , in any area ( been there , done that) third : it's easy to be confused , when you don't have enough knowledge ; taking step by step , as you obviously choose , is wise thing now - what answer you prefer : - fast and simple -slower but thorough ? for second one you need to provide more data for your xformers and caps
#8 |
Zen,
the OP wants to know what to buy in addition to his existing stock. He can build a simple PSU and that prepares him for the real job and also gives him knowledge on which to base his buying decisions. I cannot tell him what is "best". He has to make informed decisions. Start the build !
regards Andrew T. |
#9 |
Zen the problem is that I bought the capacitors before I really understood the requirements of the circuit. I am not technical, but felt that more is better without really understanding. I then discovered CLC and the issue of placing capacitors across the bridge. My original intention was to build a simple CRC circuit, but then a little knowledge is ...
Andrew I cannot really make an informed decision. My lack of knowledge is a limiting factor. Do I really need to spend a small fortune on buyng more capacitors, when I have quite a few that will suffice. PSUD seems to show that the first capacitor in the network does not need to be enormous, but must ripple tolerant. Hence my quote. 90,000uF per rail should be enough, but I do not know this for sure and I am concerned that I am missing something (e.g. the role of ESR). Nick |
#10 |
give me :
voltages of xformer - both pry and sec Rdc ( use DMM ) for both pry and sec ESR of caps , taken from datasheet are you able to purchase custom made EI chokes ?
| Voltage regulation on F5 power supply? | majerjack | Pass Labs | 3 | 16th September 2010 12:51 AM |
| F5 Power Supply Caps Seem Small | NV&H | Pass Labs | 3 | 23rd January 2009 01:41 AM |
| Converting this power supply to 127VAC (not the mains) | -_nando-_ | Power Supplies | 6 | 31st May 2006 04:48 PM |
| 2A3 monoblock power supply | tenderland | Tubes / Valves | 19 | 21st March 2006 03:36 AM |
| Power Supply for 300B Monoblock | kmtang | Tubes / Valves | 0 | 6th March 2005 01:56 PM |
| Page generated in 0.10736 seconds (82.88% PHP - 17.12% MySQL) with 11 queries |
