Old 4th January 2011, 10:50 PM   #1
Default unstable PSU for aleph-x à la ZenV9
Hello,
I started trying to tune my first mono-amplifier combining the ZenV9 and the alephX designs.
I built 2 power supplies to get the negative VGS of the LU1014D. The main one is CLC and the second one is regulated with a circuit similar to the P1.7 PSU.
Most of the circuit seems to behave correctly compared with simulations and with Nelson's construction notes of the zenV9 ... but I have a problem with my "power" PSU.
The PSU is unstable, both negative and positive rails vary all the time by circa +/-50mV around +/-20.5V. The empty voltage is ~25V stable.
Do you have any idea to solve this problem ?
I have been stuck with this problem for a few days and I have no clue about the reason ?
the ground of the PSU is not linked to the "earth", can it be a reason ?
Thank you for your help.
Antoine
here is the schema of the PSU, the main board and a picture to make the problem more real :
Old 4th January 2011, 11:05 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
you don't need additional positive rail ;
you'll never have perfect tracking between main negative rail and additional negative rail ;
better use solution with CCS in parallel with drain resistor in LTP ( meaning each drain resistor have own dedicated CCS)
you'll still need that additional neg rail , but tracking problems are relaxed with dynamic nature of CCS
details buried somewhere in Aleph J thread - search for EUVL's solution
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 5th January 2011, 07:01 AM   #3
Hi Zen,
Thank you for your reply.
1- I agree that the extra positive rail is not necessary but I initialy planned this additionnal rail, thinking that a regulated supply for the imput stage would not be bad for the amp.
2- I recently discovered the thread dealing with the LU Vgs issue, describing the idea of a CLD in parallel with the drain resistor in LTP. But I had made my design and my PCB before I discovered this thread. In addition, I noticed that Nelson had proposed an alternative solution consisting in asserving the -- rail with the - rail to match the ripple in both rail, what I tried to implement with the extra 1000uF and 50R between negative rails.
It is maybe not the best solution but do you think that it can lead to the unstability of the main PSU (both negative and positive rail fluctuate) ?
Antoine
Old 5th January 2011, 08:06 AM   #4
Zen Mod's Avatar
in any case - you must ensure that neg rail and additional negative rel are firmly tight ; regulate that additional rail "against" main negative rail , not gnd
that way they'll "float simultaneously"
Old 9th January 2011, 05:16 PM   #5
Hi Zen,
The good news :
I increased (actually decreased) my additionnal negative rail and I regulate it with a simple lm7905 with the negative rail as reference and it works.
The PSU is stable, the offsets can be trimmed...and this first amp sings.
The bad news :
The amp do not present any humm...but...
My preamp (clone of P1.7 + xono) is noisy : there is a buzz, mainly at high frequency, which is not depending on the volume...
Do you think there is a ground loop
Antoine
Old 9th January 2011, 05:29 PM   #6
Zen Mod's Avatar
possible
how you organized grounds (especially vs. safety ground ) in both - amp and preamp ?
Old 9th January 2011, 05:55 PM   #7
possible
The same in the amp and preamp :
- "signal" grounds are not connected to the "safety ground" from IEC.
- the "safety ground" from IEC is connected to the chassis (made of aluminium)
I'll check that there is no shortcuts between chassis and grounds in the preamp
Old 9th January 2011, 06:02 PM   #8
Zen Mod's Avatar
you must connect at least one ( either in amp or preamp ) signal gnd to safety GND
best is to connect audio gnd to safety gnd in each
make that in Papa's way - through 10R-30R NTC ; not tiny one ; he use CL60
Old 9th January 2011, 06:09 PM   #9
Thanks for the advise,
I'll try to find this big NTCs.
There is no one in my amps because I did not manage to find it. No doubt that I would have done as Papa does if I could find some of them...
Old 9th January 2011, 07:25 PM   #10
Zen Mod's Avatar
have you any tossed PC PSU ?
there is always at least one NTC on input side
Is Aleph 2 unstable < 6 Ohm??? Thago Pass Labs 4 13th July 2007 10:29 PM
ZenV9 or Aleph 30? boonedog Pass Labs 29 6th January 2007 12:53 AM
zenv9 question b16a Pass Labs 1 10th August 2006 07:36 AM
A Half ABC Lost In GC La La Land S.C Introductions 3 6th March 2004 03:06 PM
Unstable when connecting PSU Nysan Solid State 0 28th February 2004 04:10 PM
Page generated in 0.10645 seconds (79.67% PHP - 20.33% MySQL) with 11 queries
