diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Balanced Operation (http://www.diyaudio.com/forums/pass-labs/18019-balanced-operation.html)
gchrist 21st July 2003 02:09 PM
Balanced Operation
Dear fellows,
I am reading the Balanced line stage article from Pass but I have this question to make:
The circuit does not amplify any portion of the signal which is the same at both inputs. It will only amlify the difference of the two imputs.
Question: The two inputs are with opposite phase. Will the difference between them always be zero? Then what does the circuit amplify?
George
Holger Barske 21st July 2003 02:23 PM
Not the difference is zero, the sum is :nod:
The difference ist what is amplified.
If you would simply subtract both inputs, you would get a result wich has double amplitude of one of the both inputs.
Resources saved on this page: MySQL 18.75%
