#11 |
Very interesting.
Basically the course is: Ground board-----post (isolated)---- chasis żNot? Regards |
#12 |
Yes, that is what worked for me. Wayne suggested to start with the chassis not connected, as it can be quieter that way. I tried it, but connecting the chassis was quieter. Try it both ways, one will be better.
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
#13 |
My setup is much more complicated but I have to keep trying.
Out put ground--- post (isolated)--- Ground Loop Breaker---- IEC earth |
#14 |
I do not have the PSU IEC earth connected to the RIAA box. The safety earth is only in the chassis that holds the PSU. The umbilical has only DC + and - , those connect to the RIAA circuit board, and never touch the chassis.
What noise I have in the circuit is the same regardless if the PSU is powered on or not, and even if it's connected or not! There are no bleeders in the power supply, the circuit will run for about 40 seconds once the power is off. About 30 seconds if you unplug the umbilical completely. There is a lot of supply capacitance. I need to try a groundbreaker on the RIAA chassis connection. That will be my next step.
#15 |
I will test your configuration of Ground
#17 |
I'm not sure what you mean...
I will be happy to help, can you be more specific? Thanks!
#18 |
#19 |
Beautiful!
#20 |
Pearl 2 boards! Very nice! I like the look of the mirror-image.
Don't forget to use the PCB starground - the hole above C12 and below C4.
| Pearl Two | wayne | Pass Labs | 1512 | 24th May 2012 02:24 PM |
| RIAA caps for Pearl and Pearl 2 | AudioLapDance | Pass Labs | 5 | 12th May 2010 08:12 AM |
| Pearl need help | dzkh63 | Pass Labs | 1 | 26th September 2006 03:16 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| Page generated in 0.09876 seconds (78.44% PHP - 21.56% MySQL) with 11 queries |
