Hello mr Pass
About your document; Audio, distortion and feedback. How do you proceed to do the IM thd test with 7 non-harmonically related tones ? Thank Bye Gaetan |
#2 |
The one and only
This was done by simulation. In this case, I have arbitrarily
picked 7 frequencies of equal amplitude from a fundamental of 1 up to 29 and calculated the distortion through a device having 1% 2nd and 1% 3rd harmonic distortion and displayed the input waveform vs the distortion. You could do the same thing with 7 generators and a low distortion subtractive circuit (given the high numbers, any decent op amp would do) There is nothing special about the test - I simply wanted to illustrate how badly this stuff piles up.
#3 |
Hello mr Pass
Did you used LTspice ? If so, do you still have the sim file ? I would like to use your SPICE directive and try that simulation with my diy amps circuit using my LTspice software. Thank Bye Gaetan Last edited by gaetan8888; 19th December 2010 at 09:14 PM. |
#4 |
The one and only
I used Excel
#5 |
Lightning In A Bottle
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
#6 |
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#7 |
I'm a tad disappointed, Papa. I would have thought you had used a log-log-decitrig slide rule!
#8 |
The one and only
I needed some automated graphics-
I don't have all the time in the world.
#9 |
Papa..... Point well made......
Although I don't think I could have gotten through college physics without my K&E 'rule...... But then again, I think we only had three elementry particles to contend with, "back in the good old days"....! May you have a great holiday season, Mr Pass. And may your 2011 be filled with only the most enjoyable products of the Napa and Sonoma Vallley.....!! |
#10 |
Hello mr. Pass
Again about your document: Audio, distortion and feedback. There is this graphic, I include an image of it. In this graphic and theoretically the best sound are at both end of it, so; an amp with no feedback or with 40 db feedback will have a very low distortions in the higher thd harmonics, and so a better sound. After tests and listening tests on various amps circuits, I found out that if I use a high level of global negative feedback the amp sound much less good than if I use a low level of global negative feedback. From your experiences and knowledges, do you have any explanations of why, even if according to the graph, a 40 db feedback will give very low distortions in the higher thd harmonics, in reality it sound much less good than if I use a low level of global negative feedback ? Thank Bye Gaetan Last edited by gaetan8888; 11th June 2011 at 11:26 AM. |
| A question for Mr Pass on mosfet distortion | pro | Pass Labs | 4 | 8th November 2009 06:25 PM |
| Paging Mr. Pass, Mr. Pass pull my finger please. | khundude | Pass Labs | 2 | 5th December 2008 04:11 AM |
| Question to Mr. Pass | Metric | Pass Labs | 7 | 19th April 2005 10:13 PM |
| A Question for Mr. Pass (and all..) | W.O.L.F. | Pass Labs | 4 | 12th March 2003 12:59 AM |
| demagnetizing (mr. feedback question) | Fred Dieckmann | Everything Else | 44 | 4th November 2002 11:34 PM |
| Page generated in 0.09466 seconds (84.94% PHP - 15.06% MySQL) with 11 queries |
