Old 9th December 2010, 11:03 PM   #11
frags is offline frags  Canada
Originally Posted by Russellc View Post
Is there a prefered spring rate for this application?
Now you will have sleepless nights thinking if your washers provide proper pressure on FETs.
PS. I always use spring (split) washers. No problem so far.
Old 9th December 2010, 11:05 PM   #12
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
Originally Posted by Nelson Pass View Post
That's the best. You can buy them at various spring values.
Is there a fender washer (smaller hole) version of these?
Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 9th December 2010, 11:45 PM   #13
EUVL is offline EUVL  Europe
IMHO, a Belleville washer (or conical waher) first appears to be the ideal solution, in that it exerts pressure uniformly around the perimeter, which is not the case for the humble spring washer. However, if you would tighten a screw with a conical washer till flush (totally flattened), and then release it again, you would find that the conical washer would have been deformed and lost a sigificant proportion of its conicity (and hence the ability to generate preload force).
Or in simple English, a conical washer should never be tightened till flush, but only be tightened using some form or torque control, so that it is given the right preload within its designed working range.
Disc Springs to DIN 2093
(Note stress level vs deflection)
Heavy Duty Bolting Washers
Patrick
Old 10th December 2010, 11:54 AM   #14
Just to confirm the earlier comments on the difference between "shakeproof" and "constant load" washers.
The split washer, the serrated washer and similar are to prevent an improperly tightened nut/bolt/set screw from vibrating off. Similar to self locking nuts.
The "Belleville" washer is one type of constant load type fixing. It is designed as an elastic "spring" between the underside of the nut/head and the device to be clamped.
A stack of Bellevilles can be used to arrive at different spring ratings.
Two Bellevilles one inside the other has roughly double the spring rate (force change as distance changes, eg. due to temperature exapansion) and double the holding power (twice the force).
Two Bellevilles facing in opposite directions have half the spring rate and the same holding power. Combinations of opposite and same direction series Bellevilles can achieve many different loads and stiffnesses.
Old 10th December 2010, 12:00 PM   #15
tinitus is online now tinitus  Europe
I expect the split washer will need too much pressure to have an evenly load, and not good
Old 10th December 2010, 12:26 PM   #16
the split washer needs very little force to squeeze to flat.
As the fixing slackens off the two cut edges expand out and dig into the surfaces to prevent further unscrewing. By this stage the fixing is "loose" with very little clamping load. The split washer has done it's job. It stops the joint falling apart and the nut/bolt falling out.
Old 10th December 2010, 02:51 PM   #17
All,
Just my two cents. Consider using a thread-locking compound, such as Locktite 243. We routinely build high-performance road racing engines that rely upon accurate and reliable fasteners, to endure through many heat cycles, and under the worst condidtions. We would not assemble a $50,000 engine without the use of Locktite on critical fasteners.
I'll be using it on my F5 MOSFET machine screws. If you use it, just be careful--a little goes a long way, and avoid getting it on the heatsink base or the heatconducting substrate of the MOSFET. I have never considered the "thermal impedance" of Locktite, but I'd assumine it's not a good conductor of heat.
Old 10th December 2010, 09:42 PM   #18
The one and only
Nelson Pass's Avatar
McMaster Carr
Old 10th December 2010, 09:50 PM   #19
expert in tautology
bear's Avatar
The split one is commonly called a "split ring lockwasher"... fwiw. At least it is around this part of the NE USA...
There are also internal and external tooth lockwashers...
I've never had a problem with screws holding output devices getting loose when properly torqued and using a "tooth" type lockwasher on the nut side. I also use a small washer to spread the down force on metal tab type transistors, not on older TO-3 type metal packages.
Locking compound would not hurt... I guess... the Belleville washers are nice... but I personally have never needed to use them...
_-_-bear
PS. if only a 4-40 size was the available through hole (a plastic pak that can't be drilled) I'd
add a bar to hold the entire face of the plastic pak device as well... talking F5 sized power devices,
not <5watt plastic paks...
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Curious LED failure mode Steerpike Parts 5 5th April 2009 09:15 AM
Familiar Sonic Impact Failure Mode? Buckapound Class D 8 3rd January 2007 07:58 PM
Primary mode of transistor failure Bama Slamma Solid State 1 27th October 2006 02:50 AM
6C33C-B Failure Mode? Alastair E Tubes / Valves 4 2nd July 2005 08:03 AM
strange transformer failure mode capslock Solid State 9 27th March 2003 09:58 AM
Copyright ©1999-2013 diyAudio
