Semisouth SJEP120R100 Power Loss
Old 30th November 2010, 10:02 PM   #31
chip_mk is offline chip_mk  Macedonia
Well, then what do you think, what could be that bl**dy thing in the corner?
- It looks like 2-3mA @1.5V Vgs
- It rises at lower Vgs
- It isnt dotted line meaning its measured at 25C
As temperature rises the curve moves to the left and Ig becomes immeasurable, in most cases. Spavleski has apparently OK device but it shows some measurable Ig that disappears after warm up. Could it be an expected behavior with variations from device to device? Or simply the chart is misprinted?
Old 30th November 2010, 10:15 PM   #32
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by spavleski View Post
At the moment Bias is set to Id = 1,85A and Vds = 20V with inputs grounded. Sound is
sound - with inputs grounded ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th November 2010, 10:16 PM   #33
Seriously speaking , most probably it is about bad contact connection during measurements. Soon I will replace 3W resistors with a MOX type, and will take out the boards and will re-check one more time.
Sorry to bother, would you care (for the sake of science) to measure Vgs along with Igs next time? It seems Ig becomes measurable at cold start and with lower Vgs (is it too complicated to try it with lower bias current?).
Old 30th November 2010, 10:20 PM   #34
Zen Mod's Avatar
I have impression that Papa already said his results ........ and he certainly have more specimens to play with
I know for 12 pcs of SSouths in entire Serbia
even if you triple that .... it's funny
Old 30th November 2010, 10:58 PM   #35
spavleski is offline spavleski  Serbia
spavleski's Avatar
Semisouth SJEP120R100 Power Loss Semisouth SJEP120R100 Power Loss
I'll play a bit soon (in a week or two), during MOX replacement. Will post findings here.
PSMLS CookBook by ZM
Old 30th November 2010, 11:00 PM   #36
spavleski's Avatar
After Bias setting and connecting some music
Old 27th November 2011, 10:29 AM   #37
mr.tubefan is offline mr.tubefan
Exclamation Any news ?
Yesterday I found the same problem in my new tube / Jfet project. Using a pair of the SJEP120R100A having highly different gate input currents :-( The driver is a 6SN7 @ 8 mA cathode follower. It seems to work after 30 minutes screwing at the pots and increased heatsink temperature....
Looks like this strong variation in the Jfets will needs extra attention...
Tubefan
Old 2nd March 2013, 11:46 AM   #38
EUVL is offline EUVL  Europe
We were very lucky to be able to get hold of a sizable batch of SJEP120R100s.
Today we took 9 of them out at random, and curve traced them.
Vds was 25V, and case held at 25C by a huge block of aluminium.
No time to heat up to 60C today.
You can judge for yourself the chances of getting good match sets with a small matching pool.
At current asking prices, rejects will be horrendously expensive.
Patrick
xen-audio.com
Old 2nd March 2013, 11:57 AM   #39
buzzforb is offline buzzforb  United States
buzzforb's Avatar
EUVL,
While Vgs defintely appears to be all over the place, have you had a chnce to check for consistency of Yfs? I have 8 that are pretty well matched, just have to check their yfs. Also, will you be checking for leakage?
...Shape the sound , Man!
Old 2nd March 2013, 12:57 PM   #40
If you cannot find proper Vgs pairs, why would you bother with the other two parameters ?
Patrick
xen-audio.com
Semisouth SJEP120R100 Power LossHide this!Advertise here!
Semisouth SiC JFETs: SJEP120R100 or SJEP170R550 better for building amp? zhoufang Pass Labs 33 16th March 2015 10:56 AM
SemiSouth SiC Power JFETs RocketScientist Solid State 105 19th February 2012 08:02 PM
HELP! my amps loss power rrlax24 Subwoofers 1 8th November 2006 08:02 AM
Passive Pre-Amp causes huge power loss? Dominick22 Tubes / Valves 9 28th September 2006 10:34 AM
