Hi All,
I need help to solve the problem. I just completed the aleph J and noted a very loud cracking sound through the loudspeaker on switch off of the power supply. It is very quiet on switch on and no hum at all. The dc offset at output is less than 0.2 V but swing to about 1 to2 V on powering down. I am using a CLC type of line filtering with about 200000UF caps. The L is wound on a EI transformer , diy type. I also use about 11 uF of motor start non polar caps at the last stop. Could this be the problem ? appreciate all the help kp93300 |
#2 |
Hi kp9etc,
Sounds very much like arcing inside the power switch. Suggest you put snubbers/switch click suppressors across each section of the switch, consisting 0.1µF "Y" type capacitor in series with 100-120R resistor, or buy them ready made from RS or farnell. John |
#3 |
you can check John's idea with simple test - instead of using mains switch to power off amp - just plug power cord from wall .
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#4 |
Good idea Wilson, didn't think about that one, Capt. Mainwaring
John |
#5 |
#6 |
pictures , please
#7 | |
Can I use x2 rated ? Is the value of 0.1uF critical ? Smaller and larger value ? thanks kp93300 |
#8 | |
considering this :
this will not help : problem is somewhere else , not in power switch
#9 |
These are some pictures of the aleph j that I build.
The transformer is in another box. The pre is J310 and Lightspeed clone as the attenuator. hope i can find some pointers in troubleshooting this problem. kp93300 |
#10 |
Some more pictures of the build
| Cracking sound from amp - help | Brit01 | Solid State | 5 | 8th August 2009 01:13 PM |
| Zenith K731 AM/FM radio audio random cracking sound in FM mode | AC439 | Tubes / Valves | 15 | 20th February 2009 09:06 PM |
| A problem of cracking sound amp | gaetan8888 | Solid State | 15 | 8th July 2007 07:41 PM |
| Cracking sound through speakers. | magpietim | Tubes / Valves | 5 | 23rd October 2005 03:53 PM |
| Why can 8W sound as loud as 100W? | AudioIsFun | Tubes / Valves | 19 | 26th January 2004 03:05 PM |
| Page generated in 0.10094 seconds (78.14% PHP - 21.86% MySQL) with 11 queries |
