My Aleph3/5-BA-2-Semisouth-J2 Clone Monster - Page 6 - diyAudio
Old 24th November 2010, 02:42 PM   #51
generg is offline generg  Germany
generg's Avatar
Hi Bill, Hi Zen Mod,
the new news... yesterday I was very convinced I would measure the AC current delivered by the Semisouth and by the CCS like Nelson suggested.
this morning bevor I took out the soldering iron, I heard some music and because I had yesterday implemented three resistors for R21, the one that feeds back the signal to CCS, I switched only the three values 750 Ohm, 500 Ohm and 310 Ohm.
Result: less Ohm, louder sound, CCS contributes power
More result: sound got more and more darker, not unpleasant.
more more result: definition got worse
difficulty: changing the volume to get the same level between the steps
surprise:without any resistor (Nelson mentions this possibility) - best definition, most airy sound, nearly too soft, but impressive - a must hear
conclusions:
- because Nelson shows the decrease of distortion by using aleph ccs it must be the blend in of the IRF240, that takes away definition. I will not speak per se against the IRF, may be the mix does not work well or there is no way back the SemiSouth is simply better.
- would be interesting to replace the IRF by a Semi, I know it is not recommended, but i am interested to hear the blend with two SemiS
- small signal j-fets and SSouth are unbeatable for resolution, airiness and more or less analogue softness. (the same experience I made with ZMs Babelfish J2, being more precise, less soft)
next steps: I will try three models CCS for the differential pair, original A5 with IRF9610, two or three SK170 (see frontstage BA-2) and the solution of aleph J
and look for the sound and hum..
happy generg
and the First Wtt is......a really First Class PSS Idea
Old 24th November 2010, 02:57 PM   #52
RIP
Hi generg, removing the resistor turns the aleph circuitry off, making it a CCS. If you want to experiment more, increase the resistor to 1.2K or higher, that gives less AC current gain.
Old 24th November 2010, 03:03 PM   #53
generg's Avatar
yes Bill, I know and I did not want to do it because I wanted by the aleph CCS the more of power I needed for my four Ohm speaker but
as described the sound without is simply better....
Old 24th November 2010, 03:20 PM   #54
RIP
I understand. If your heatsinks are large enough you can increase the bias for a little more power capability.
Old 24th November 2010, 03:22 PM   #55
generg's Avatar
yes I will do this!
but first the little research about aleph with two identical semiconductors...
Old 24th November 2010, 03:35 PM   #56
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
I believe that small BJT will be starving at such low E-C voltage ;
anyway - be sure to set AC gain to desired level ...... because it is in function of Aleph CCS active output device
I know what's my fave , if nothing else than from engineering reasons
be aware that I'm not an engineer
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th November 2010, 05:04 PM   #57
generg's Avatar
o.k. I heard the aleph current source with two SemiS in the lower and upper half.
I tried all three values again and the change in sound to the darker and less resolution is not remarkable. BTW this are only small changes, nothing to get grey hairs....
means, with aleph current source its better to have to similar......
and two IRF will behave well also....
Old 24th November 2010, 05:14 PM   #58
generg's Avatar
and Zen Mod
is there any danger by the low E-C voltage for the small BJT or my amplifier, is their function not o.k. or what will happen...?
Old 24th November 2010, 05:33 PM   #59
flg is offline flg  United States
flg's Avatar
Exactly, except I'm not the "ZenMod". Look at the data sheet and the saturation charactersics.
I suggest an EF xistor from Colector of the the CSS "regulator" to the Gate of the CSS FET. Then the ZTX (BC whatever) has just enought EC voltage to operate well.
Choose.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 24th November 2010, 05:57 PM   #60
generg's Avatar
Hi flg,
Exactly
should I not switch on the amplifier?
I did not know the expression, I found "xistor" means "transistor" but what is "EF"? three legs? four legs are good, two legs are bad....
sorry.....
FirstWatt J2 Blues Pass Labs 1052 31st December 2016 09:12 AM
F3 vs J2 for a SET guy Paul Folbrecht Pass Labs 24 27th May 2010 10:16 PM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 03:35 AM
The simplified schematic of J2 what I suppose to be. wensan Pass Labs 9 16th November 2009 10:09 AM
Adcom J2 8934m Ardvaark Parts 0 23rd July 2009 06:30 PM
Copyright 1999-2017 diyAudio
