My Aleph3/5-BA-2-Semisouth-J2 Clone Monster - Page 4 - diyAudio
Old 23rd November 2010, 03:47 PM   #31
RIP
That is correct, but double check your offset to be sure it is close to minimum.
Happy listening!
Old 23rd November 2010, 04:07 PM   #32
Johnloudb's Avatar
Originally Posted by generg View Post
Paint is for sure the better choice, but I changed to Mac OS X......
Every Mac owner needs Graphic Converter. It's an image editor and image file converter.
Lemke Software GmbH - Aktuell
My Website: Hyperacusis, Tinnitus, My Story
Old 23rd November 2010, 04:30 PM   #33
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
Generg - I'm not sure now what was a call regarding value of R14 ;
Bill told you just to check voltage across it - to determine current through left side of LTP and compare is it 50% of overall LTP current
value of R14 is dependable of needed (Ugs+Urs) for desired output Iq and don't have anything with proper current share in LTP itself
varying LTP current and R14 value will vary OLG and feedback ........ but that's another part of story
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd November 2010, 04:54 PM   #34
generg is offline generg  Germany
generg's Avatar
hm, hm....
you both know to much for me to discuss your thoughts, but I can do what you suggest and hear the sound and get more feeling for theory reading your comments .....
I will try different values in the range opened by the discussion and given by Nelson.
In A3 the current through the differential pair is also around 20mA ....if I read the SM correct, in A3 and A5 the values he suggested are 750 and 450 Ohm.
next days I will measure with a 60Hz tone the voltages Nelson described in Zen Variations 2, just for fun, learning something new....and never giving up....
and the First Wtt is......a really First Class PSS Idea
Old 23rd November 2010, 05:16 PM   #35
RIP
I believe there is a slight language barrier. Please read my post again. I have taken into account all the points that you mention. The Vgs of the R100s determines the voltage needed across R14. If the offset is minimal then it is in the correct range, and then the voltage drop divided by the proper current determine the proper resistance. If the amp is operating with high offset, the voltage range for the R100s will be incorrect and will throw the current sharing off in the front end.
Old 23rd November 2010, 05:23 PM   #36
Zen Mod's Avatar
there is sometimes just too much for typing .......
NB that 5mA per input jfet is good
also - 10mA - as in FW J2 is good for driving one output gate
two input Jfets have x transconductance
that combining with y value of needed drain resistor at 10mA of current will give exactly Ugs+Urs for Iq of ~1A5 to 2A ...... and that will give z OLG , which - combining with feedback net set at 10x will give xx db- of feedback , giving yy output impedance ...........
rise time , blahblah ......
so - conclusion - whatever stage you think of ......... just let it bleed
Old 23rd November 2010, 05:28 PM   #37
Zen Mod's Avatar
Originally Posted by Bill Fuss View Post
I believe there is a slight language barrier......
there are 3 of us here , in this moment .....
I wasn't sure that Generg is following you - at least in moment when he started to write resistor values , instead of currents/voltages through LTP and each half of it
so - I think that I know what you were saying ....... but wasn't sure what Generg is measuring
one more thing - Generg - voltage accross drain resistor in input LTP seems little off - decreased at least for value across output Jfet source resistor ?
Old 23rd November 2010, 05:31 PM   #38
RIP
This ain't rocket science. I think Generg gets it. If he works through a couple of NPs previous Aleph front ends he will get it.
Old 23rd November 2010, 05:37 PM   #39
Zen Mod's Avatar
This ain't rocket science. .........
yup
..... I think Generg gets it. If he works through a couple of NPs previous Aleph front ends he will get it.
for sure ; Generg is ..... Generg !
seems that little confusion started in multilateral chat
Old 23rd November 2010, 06:03 PM   #40
generg's Avatar
Hi Zen Mod,
measured 1,9V across drain resistor input LTP and 0,5V over source resitor of SS is 1,4V, not a good value for Vgsthreshold?
FirstWatt J2 Blues Pass Labs 1077 28th February 2017 05:10 PM
F3 vs J2 for a SET guy Paul Folbrecht Pass Labs 24 27th May 2010 09:16 PM
FS: two burning amps (one each BA-1 and BA-2) without drivers Eric Weitzman Swap Meet 15 17th February 2010 02:35 AM
The simplified schematic of J2 what I suppose to be. wensan Pass Labs 9 16th November 2009 09:09 AM
Adcom J2 8934m Ardvaark Parts 0 23rd July 2009 05:30 PM
Copyright 1999-2017 diyAudio
