Mezmerize DCB1 Building Thread - Page 9 - diyAudio
Old 10th December 2010, 09:55 PM   #81
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Ignore that. The BC517 worked better than BC546 originally there, we had to occasionally add that cap there to avoid the startup relay from ocilllating.
So 4 100uf caps for Power supply , 1 for relay cap.
The board is labeled correctly for all needed parts.
Salas Boards GB 2017#1 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2CBoards and transformers In stock PM for details
Old 10th December 2010, 09:58 PM   #82
Thanks, I thought I was going mad.
Old 10th December 2010, 10:23 PM   #83
Originally Posted by Salas View Post
Its all ready there for you. There is 12V supply on board -connected as it should, you do nothing- and there are 1...6 positions for the steps pins and gnd for the switch's output pin. Half a stereo switch does the trick.
The other half for input identification via leds...
Old 16th December 2010, 02:18 PM   #84
Actually it's still not clear to me as well how to connect the input selector. I have 7 pins. What do I have to connect to the common pole of the selector ?
I fired today for the first time the board. Everything looks good. I have one rail a bit lower than the other. Additionally 0.1 mV DC offset on one channel and 1.8mV on the second channel. Is it normal ?
Thanks,
Davide
Old 16th December 2010, 03:47 PM   #85
udailey is offline udailey  United States
Davide
It looks like congratulations are in order. Your offset is wonderful. I think one rail actually is supposed to be lower than the other but by how much I dont recall.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 16th December 2010, 03:58 PM   #86
khaho is offline khaho  Finland
There is text beside the pin row, SELECTOR 1,2,3,4,5,6,GND.
So the pin closest to the text is GND and connecting it to the 1,2,3,4,5,6 pins will drive the corresponding relay.
Hopefully this helps.
Old 16th December 2010, 09:18 PM   #87
Thanks,
Davide
Old 17th December 2010, 01:33 AM   #88
It does. :-)
Thanks,
D.
Old 19th December 2010, 06:37 PM   #89
Horio is offline Horio  United States
Horio's Avatar
Originally Posted by Tea-Bag View Post
Horio,
Let me correct myself first, it's the first cap that gets replaced, not the second.
Technically I am not positive what the differences are. Both are bypass caps for the IRFP Voltage Reference. The film cap seems to offer better sound. I would buy both and try both.
Tea-Bag
I'm getting ready to solder in the caps, and wanted to make sure I put the 0.1uF cap in the right spot. I should be replacing the two 100uF caps closest to the Vref LED strings (5 LEDs) for hot-rod?
Old 19th December 2010, 10:59 PM   #90
Tea-Bag's Avatar
Yes. I just looked at the boards.
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 07:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 10:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 09:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 04:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 07:25 AM
Copyright 1999-2017 diyAudio
