Mezmerize DCB1 Building Thread
Old 13th July 2013, 10:26 PM   #801
HiFi Rookie is offline HiFi Rookie  United States
I have ordered the board now through DIYaudio. Ordering parts I find the Jfet is no longer carried with Mouser. I will look at other sites, any preferred?
What is "matched" vs. "unmatched" N-jfet?? How do I know which I am ordering?? I need 4 of one and 6 of the other.
Thanks!!
Old 13th July 2013, 11:45 PM   #802
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by HiFi Rookie View Post
Thanks! what are a couple sites you would recommend for purchasing RCAs?
Will I need any additional components (other than the diyaudio parts list) to set up volume control?
Beyond the Alps pot itself, extension shaft and some knob.
Try Ebay USA stores for Neutrik Rean NYS367.
Old 13th July 2013, 11:51 PM   #803
Salas's Avatar
Thanks!!
Matched means same IDSS parameter. They bias with small offset voltage that way.
Ask in the swap meet forum here, maybe some members can offer.
Or ask this guy:
Store | FET Audio
Old 15th July 2013, 02:24 AM   #804
kop89 is offline kop89  United States
Default Volume pot connection
About the volume pot terminals on the PCB, can anyone confirm which holes are for input, ground, and output for each channel?
I could have found out by looking at the back of the PCB, but forgot to do that and the PCB's already mounted with IRFPs greased to the chassis
Thanks!
Old 15th July 2013, 12:38 PM   #805
Salas's Avatar
Top view
Old 16th July 2013, 11:36 PM   #806
Default mezmerize build
So I have ordered everything I can from Mouser, Farnell, DIY HiFi audio supply... etc.
I need help, if someone would be soo kind, finding where to order the correct parts for my mezmerize build:
-Decoupling A 150nF/63v
-12v Relay 2 poles
-05v Relay 2 poles
-Fuse 115V (not sure which one to get)
-Fuse 230V (not sure which one)
-Jfets matched/unmatched
Thank you to the person that can help the newbie out (Salas)! Also, a link to your preferred transformer for this build would be greatly appreciated!!!
Old 16th July 2013, 11:38 PM   #807
Oh and
how about a link to your preferred pot for this build (volume control).
Old 17th July 2013, 01:40 AM   #808
Gooch is offline Gooch  United States
Gooch's Avatar
Oh and
I just bought mine from here 10K, Blue Velvet - STEREO
I got my jfets for here Resistors, MOSFETs items in AudioFET store on eBay!
Relays from mouser 551-EA2-12NJhttp://www.mouser.com/ProductDetail/...fFWinIjg%3d%3d
Old 17th July 2013, 02:15 AM   #809
Salas's Avatar
For primary inline fuse you may divide your transformer's wattage by your wall voltage.
Prefer 12V relays and put a wire jumper where it says 'note' on the PCB, they heat the 7812 less.
Decoupling you will most possibly not need if you got the BC517 relay driver transistor.
Old 17th July 2013, 03:15 AM   #810
Thanks Gooch! That helps a lot.
Is this 5v relay ok? I picked up the NEC 12v relay you recommended.
Mouser # 653-G5V-2-H1-DC5
http://www.mouser.com/Search/Product...3-G5V-2-H1-DC5
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
