Mezmerize DCB1 Building Thread
Old 10th February 2013, 05:32 PM   #701
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Use your first scheme. Then tie wrap the lot together so to have narrow loop area till the harness meets the board's connector.
Old 22nd February 2013, 06:20 AM   #702
juanitox is offline juanitox  France
juanitox's Avatar
Hi, i have a dac with +2.6v dc offset do you think it is posible to go dc coupled on a dcb1 having 10v on positive rail and -12,6v on negative rail?
French is not a crime.
Old 22nd February 2013, 04:26 PM   #703
Salas's Avatar
No, it will keep transferring the offset to the output because its on the gate. Capacitor couple the DAC.
Old 12th March 2013, 12:16 AM   #704
Eric is offline Eric  United States
Eric's Avatar
I've been reading DCB1 threads for what seems like a long time now and have a question about the bias setting. I have most of the parts and will begin assembly soon.
My plan is to build a hot rod version of the Blue Mesmerize board, somewhere in the 400-600mA range. The irfp240 and 9240's will be adequately sinked, but can someone please explain to me how this affects the output sound quality? Where does this extra bias current "go"? In my Aleph-x amps, the extra bias through the output devices improves sound quality, but I don't see how the 170s in this design can pass the extra current...
I'm sorry if this is a basic question or this was described before - I didn't find a description of this in my reading.
Thanks in advance!
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 12th March 2013, 12:31 AM   #705
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
It doesn't get used. It's essentially mostly waste heat. Same is true for the most part for the Aleph-X, however they are biased directly.
In this case, the power supply is rev'd up to potentially give a lot of ma, but it uses very little, taking only what it needs. Subjectively it sounds better. Making the soundstage a little more sweet and also solidified in my experience.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 12th March 2013, 02:11 AM   #706
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Would someone update the BOM to account for EOL products such as the recommended relays?
Old 12th March 2013, 11:08 AM   #707
Eric's Avatar
Thanks Tea-Bag, this makes sense to me. I was going crazy trying to figure out how increasing the bias would alter the output in this case...
I'm trying to plan out the physical configuration now. I'm planning a stand alone preamp using the DCB1 + Lightspeed attenuator and was thinking about building a DAC into it as well. So many choices...
Old 13th March 2013, 07:44 PM   #708
Salas's Avatar
This is what has been recommended in the past: NEC EA2-12NJ
http://nl.mouser.com/Search/ProductD...ey551-EA2-12NJ
Fully compatible and equal quality if not better. NEC has great rep for small relays.
Old 13th March 2013, 09:14 PM   #709
Stixx is offline Stixx  Germany
Stixx's Avatar
I am currently building a Mezmerize buffer to (possibly) serve as a new pre in my system.
I voted for the Mezmerize because of the input option.
Having read a fair bit on the threads (including DCB1) I am planning to sort of hot rod my Mez a bit... current set resistors are two 12Ohm in // (for about 275mA?), diodes are HFA08TB60 (had them in my drawer), semis will be heatsinked to the bottom of the future case via two solid aluminum rods, and the input capacitance will have some hefty assistance by off board fellows.
There is still a few parts missing, and I've got two questions: I was planning to substitute the two first 'lytics in the regulators with film caps, but space is rather limited. So I could mount some decent film cap off board, or just use 'lytics also. How sensitive is this to sonics (subjectively ), and how critical is the value? I have 47uF 50V and 1000uF 25V (again both in the drawers)...
And then there is the 10R under one of the K170's on the board: I read in the other thread that this one has to be changed to 1R. Is this mandatory (because the 10R are already soldered in...? and I hate desoldering
Old 14th March 2013, 03:59 AM   #710
Salas's Avatar
Use 100uF (47uF are also acceptable) on the first caps positions now void on your PCB. One thing that works nicely is 220nF COG + 0.33R SMD parts snubber directly on its leads at flip side. DON'T do that on the output lytic. Also 10R to 1R ain't mandatory. I have "voiced" the MEZ using different subtleties than in the HYPNO which is poised for the heavier running aspirations so you may experiment but don't draw directly from HYPNO users experiences word for word. 12//12 Ohm is as far as I would go minding the main electrolytics ability & the bridge diodes best ventilation mounting and temp for reliability. Which is already taken care of in yours by substituting with TO-220s as I see. Good luck then.
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
