Mezmerize DCB1 Building Thread
Old 16th October 2012, 10:52 PM   #621
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Nice. When you will sort it out as a system drop us a note if all went to plan.
Old 17th October 2012, 03:26 PM   #622
Renron is offline Renron  United States
Renron's Avatar
I'll post pictures when it's completed. I've also added a 21 Ohm 1% 3 watt resistor to my 10 Ohm to hot rod it a little bit more. Now the Heatsinks get warm. Spot check with temp gun reads 93*F on the Mosfets.
Thanks for all your help.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 17th October 2012, 06:05 PM   #623
Salas's Avatar
I saw those sinks are plenty big, its gonna live a long time on them at 200mA+ you took it.
Old 27th October 2012, 03:23 PM   #624
Nikon1975 is offline Nikon1975  Austria
I have a problem, with my Mesmerize, not sure if it's a ghost, not sure what I am looking for.
Basically, when the system is powered no problem at all. I have 300mV of offset when the system is powered off. This with no connection to anything whatsoever.
The only explanation I have is that there is a capacitor trying to discharge from the output, but the funny thing is that if I shorten the output and then open it again, the 300mV come back.
I am really puzzled. It could be that I have been living with this for years.
Please let me understand.
Thanks,
Davide
Old 27th October 2012, 04:09 PM   #625
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I've just swap meet'd a bunch of heatsinks that would suit the SALAS Shunt PSU as long as you're not running crazy amps through it.
Old 27th October 2012, 07:39 PM   #626
Salas's Avatar
Thanks,
Davide
Maybe something with absolute ground potential? Make it be shorting to ground when off. Is it the pcb with a T arrangement on the output relay that does it already, or one older?
Old 27th October 2012, 09:20 PM   #627
The pcb is from tea-bag is written layout by crt, but there is no version. It's blue.
I'll make some test...no earlier than one month
Thanks,
Davide
Old 27th October 2012, 09:25 PM   #628
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
The blue one has the T-Mod.
Most Salas Boards In stock, Private Message | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Available, PM
Old 27th October 2012, 09:32 PM   #629
Salas's Avatar
To clarify, when your PCB has this detail in double layer, the output is at ground when its powered off. And you can also confirm that with a multimeter.
Old 27th October 2012, 09:37 PM   #630
I am not sure about the pcb, but when the system is off, I measure something like 100kohm. I think you are suggesting me a solution. I can add the connections.
D.
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 07:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 10:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 09:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 04:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 07:25 AM
