#611 |
diyAudio Chief Moderator
Its center tapped series to be exact.
#612 |
Thank you Salas and Tea-Bag.
Tea-Bag you called it a ground, it's really a faux center tap that I'm making. Salas, I understand exactly what you mean by Center tapped series. One happy guy now. Thanks guys. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#613 |
Onto the next question.
![]() I've scrounged some Omron G6H2 relays from various sellers, Is there a way to tell if they are counterfeit? Some have printing on the side others don't. Got a guess? Thank you, Ron
#614 |
For OMRON I am not experienced, may others will see and tell, but for NAIS I have got other made in Japan, other Made in Germany, the printing was not the same.
#615 |
Salas,
Thank you for being so quick to reply. My soldering Iron is still hot! Ron
#616 |
Another Hot Rod is Born.
![]() I've measured across the 10 Ohm resistors and I get....1.406+ and 1.436- . I'm sure it's been asked 100 times before but it's a HUGE thread. So I'll make it 101 times, where else do I measure for proper voltages? I've measured the offset (difference from neutral to L&R) on the signal pins and I get .001 and .003. Board Voltage is 9.58 and -9.42 Thanks for a very cool LED project. ![]() Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. Last edited by Renron; 15th October 2012 at 09:28 PM. Reason: Forgot to add a V |
#617 |
Measures fine. Enjoy.
#618 |
Salas,Thank you again for your help and sharing your time.
If I want to use a separate volume controller on a different board, can I jumper these two pair of outputs? I want to run the audio to a different board that has it's own attenuation. Thank you for answering my strange questions. Ron
#619 |
Yes, you can continue the signal route there. You should get 220K input resistance if you will measure across an engaged input.
#620 |
Right, thanks,
220K from the downstream resistors. That's what I thought, but I still need to be sure. Ron
| WTB Mezmerize PCB | 3GGG | Swap Meet | 3 | 16th January 2011 09:15 AM |
| FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed | korben69 | Swap Meet | 13 | 17th May 2010 12:56 PM |
| My XXLS Subwoofer building thread... | harrisni | Subwoofers | 9 | 28th October 2007 08:21 PM |
| Fave song from SOAD 'Mezmerize'? | PeteMcK | Music | 6 | 8th March 2006 03:12 AM |
| Gainclone building thread based on BrianGT's boards | meat | Chip Amps | 752 | 8th August 2004 06:25 AM |
