Mezmerize DCB1 Building Thread - Page 61 - diyAudio
Old 23rd July 2012, 07:45 PM   #601
Thanks for the feedback. Comforting to know.
I didn't see any problems with the offset on the output, so I was pretty sure it was OK.
The shunt regulator is dead silent I had problems finding any noise on the scope (highest resolution is 2 mV/div and at this setting I could barely make out some fuzz on plot, certainly less than 0.5mV). Thanks for the brilliant design. I'm thinking this would be great in a DAC.
the Mez is sitting on my desk right now. Without any load, the fins on the IRFs are not even warm.. Makes me want to try a 9R hotrod (200 mA = ca 4 x current) with some more sinking.
I'm thinking of putting it into a case together with an ODAC (USB) and an optical/Coax DAC (not yet decided, recommendations are welcome) to give me 4 analog + 2 digital inputs making it an All-in-one stereo Preamp..
I guess I could run the DAC off a second shunt reg powered by the same transformer, no?
Old 23rd July 2012, 09:28 PM   #602
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Calculate the total consumption to see if your transformer is up to the task. Using the second shunt's CCS setting.
Old 28th September 2012, 03:37 AM   #603
Renron is offline Renron  United States
Renron's Avatar
Is it possible to input DC into the Mezmerize board and increase the PS filtering? I have a separate good PS board, just curious.
Thanks,
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 28th September 2012, 06:31 AM   #604
Salas's Avatar
If you will go directly to the filter caps positions you can feed DC there. Use some cap there at least 100uF to decouple the incoming DC wiring. Watch the polarities. You don't need to populate the diode positions or the Tx connector anymore of course.
Old 28th September 2012, 07:05 PM   #605
Renron's Avatar
Thanks Salas,
Just to make it perfectly clear to me, 'cause I don't want to screw this up and I'm unsure of what I'm doing, please confirm this for me. Photo below.
1) The capacitors SHOULD be installed + / - as labeled on the board. (Caps are 4,700 uF 35V Nichicon Gold Tone)
2) The Red circle should be connected to the - negative DC input
3) A jumper installed across the Green oval , and the + Positive DC input should be connected here.
4) All jumpers on board (to connect -) should be installed.
Don't short AC-in jumper with + jumper at Green oval ( 8-0 )
Do I have this correct?
Thank you VERY much for your help.
Ron
Old 28th September 2012, 07:28 PM   #606
Salas's Avatar
1. Install 100uF 35V wiring decouple capacitors where the 4700uF are designated. If you want heavier local caps, your choice. White stripes are (-). Used to be a rock band duo also but that's OT.
2. You connect incoming GND wire from your other board raw supply there, see pics.
3. No new jumper in the specific area than the long white one. In double sided boards should be a via under the white ink also if you will do a continuity check with your DMM, but do reinforce it. All other printed jumpers ditto.
Old 29th September 2012, 03:24 PM   #607
Renron's Avatar
Salas,
Thank you for your help, I understand now.
White Stripes?
Red Stripe.........Yeah BEER!
I'm sure I'll have more questions as I progress, as it turns out my Primary PS doesn't output enough mA for a HOT ROD build. I was hoping not to run the A/C wires from the TX to the board. Careful detail to routing the wiring should work.
Thank you for your continued help with this thread.
Ron
Old 15th October 2012, 07:09 PM   #608
Renron's Avatar
Back with more questions again.
What is the maximum recommended input voltage for the Mez?
I have an R-Core with (2) 15V secondaries, when I tie the outputs to make a CT, I have 37 Volts from rail to rail. This is unloaded Voltage. The power Company pushes the voltage higher than 110-115V in my area, ~123V normally, hence the 37V unloaded.
Ron
Old 15th October 2012, 07:15 PM   #609
Salas's Avatar
20-25V DC per rail. You probably gonna get ~24VDC with that Tx at your normal local mains.
Old 15th October 2012, 07:16 PM   #610
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
That should be fine. Just dont run it in series, needs to be parallel. Run ground to center, and the hot wires to either side.
Salas Boards GB 2017#1 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2CBoards and transformers In stock PM for details
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 07:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 10:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 09:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 04:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 07:25 AM
Copyright 1999-2017 diyAudio
