Mezmerize DCB1 Building Thread
Old 28th June 2012, 02:36 PM   #581
wengtech is offline wengtech
okay i noted that for hot rodded.
one more thing, about the alps blue 2x100K pots
how about if i parallel with 100K dale resistors, that will give 50K in result.
like this:
normal 2x100K alps blue
paralleling with dale 100K
result
what do you think?
ps. i am a very beginner, please advice if anything goes wrong.
Old 28th June 2012, 04:12 PM   #582
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
is that 100K pot log or lin ?
if it's lin , read this : ESP - A Better Volume Control
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 11th July 2012, 10:33 PM   #583
Renron is offline Renron  United States
Renron's Avatar
Default A little help if you please
I purchased the Mesmerize board from DiyAudio store.
This board seems to have different main filtering cap size requirements than most of the "Blue" boards which are posted in this thread. ( I didn't see that before ordering) I'm referring to the 4700uF rated ones.
The BOM says Min. 35V, 22mm wide, with 10mm lead spacing.
This board requires ~20mm (Max?) measures 18mm wide and 7.5 lead spacing.
I'm having difficulties finding a high quality cap in the recommended value that fits this size format.
I'm sure others have run into this issue as well. Any suggestions would be greatly appreciated.
Would it be OK to just solder a couple of short legs on a snap in cap?
Heck, I'd even be OK with soldering them on the underside of the board. (may be my only choice)
The Hypno. has 4 caps the Mez has 2 caps. Is there any advantage to increasing the capacity from 4700uF to say 6800uf?
Thanks for the help.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 11th July 2012, 10:40 PM   #584
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The DIYA MEZ used the same gerber as the original Mez (mkII blue). If you got some good caps you wanna utilize be creative with their fit by all means. But use some elastic goo to bond them bases to PCB. If you gonna run it at high current, 6800uF is OK.
Old 11th July 2012, 10:50 PM   #585
Salas's Avatar
P.S. I went and got the BOM from DIY store just now for a check. I clipped the footnote.
Old 11th July 2012, 11:40 PM   #586
Renron's Avatar
Salas,
Thank you for the uber quick reply,
I must be confused, but I am learning.
I was reading the same BOM, near the top on the right hand column it says:
"Your Choice - Spacing 10mm" on the Capacitor row 4700uF.
I was also looking at a different board online which has 2 rings at the capacitor location. Hypnotize boards are different in this regard? My mistake.
However I DID find a "New" cap offered from Mouser, it is from Nichicon, the KA series. Here is what the press release says.
"NICHICON CORPORATION has developed the “KA Series” miniature aluminum electrolytic capacitor, which is intended to be used mainly for audio devices. It will be our highest-grade product ever achieving higher quality sound in audio devices than our standard 105C-resistant “KT Series.”
link: http://www.mouser.com/ProductDetail/...252b1rwHKyg%3d
Would this be an acceptable choice for this location? Or is it just marketing BS?
Ron
Old 11th July 2012, 11:52 PM   #587
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
If it is a Log B pot you don't have to worry too much about its value. The B1 is a buffer and will match it to whatever you wish to drive.
OK a 250M pot may not suit but 10K, 47K, 100K won't pose a problem.
Old 12th July 2012, 12:09 AM   #588
Salas's Avatar
Originally Posted by Renron View Post
Salas,
link: UKA1V472MHD Nichicon | Mouser
Ron
Hypnotize are different in PCB details indeed. Because geared up for even heavy hot rod, their filter caps are 4, can be fatter & snap in (2 pitches served), their CCS resistors positions are roomier.
Yummy that new cap. I would taste it if in your shoes. Nichicon has a line of such marketing caps that users seem to like, so it could be a decent good cap at the very least. See also FG series.
Old 12th July 2012, 12:12 AM   #589
Salas's Avatar
It won't be a problem indeed, but I don't recommend more than 25K for best rise time in this buffer though.
Old 12th July 2012, 12:24 AM   #590
Renron's Avatar
Sounds good! Looks delicious! And Fat free too!
"I'll by that for a dollar". well more like 5 each, I'll let you know how they work out!
Thank you for letting your humor show.
Ron
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
