Old 13th May 2012, 11:51 AM   #561
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Originally Posted by dimkasta View Post
Guys I am waiting for some mesmerize boards I got from the diyaudio store and I am currently planning on the rest of the parts.
What I was wondering is if there is a way to get two outputs from the board, so that I can drive 4 monoblock amps (dual - dual mono setup driving woofers and mid-twitters separately)
Thanks a lot
Dimitri
I just jumper the outputs together from the RCAs.
Often I use a 100R resistor from the hot signal to jumper.
I believe this can reduce noise, but I am uncertain if this is true or not.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE
Old 13th May 2012, 11:55 AM   #562
KatieandDad's Avatar
Thanks a lot
Dimitri
The usual trick is to use the Reverse Summing circuitry. i.e. feed each output through its own series resistor (for DC coupling) or a cap and a resistor (for AC coupling)
Old 13th May 2012, 01:14 PM   #563
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by atupi View Post
Forgot to ask you if worth to buy some BL grade transistors if i have matched GR transistors with Idss around 5.5
A bit less THD if you will use circa 8mA IDSS BL.
Old 13th May 2012, 02:14 PM   #564
in some locations of the DCB1 gr are the preferred grade.
Old 21st May 2012, 09:53 AM   #565
weskoki is offline weskoki  Europe
weskoki's Avatar
I had bit of accident with my Mez the other day.While listening i managed to spill some Tea on my uncased board Not full cup but still...
I fan dried it immediately and left it off.Thank God it still works.Anyway i compared the sound using the dcb1 and going straight from source to amp and i have to say the dcb1 makes Huge difference.Without it the sound is very 2 dimensional coarse and disjointed.Adding the dcb1 makes my speakers sound twice as big,dynamics are great,textures and micro details as much as you need.:And just to think i haven't hot rod it yet!
Thanks Salas
Old 21st May 2012, 10:15 AM   #566
atupi is offline atupi  Romania
I want to order some parts from Mouser and i dont know for the main smoothing caps what to choose; low ESR, low impedance or Audio grade as mouser is offering these choises.
Old 21st May 2012, 10:17 AM   #567
Salas's Avatar
Thanks Salas
Nice that you liked it. You are welcome.
Old 21st May 2012, 10:20 AM   #568
Salas's Avatar
Use main smoothing capacitors like the ones you like best in power amplifiers.
Old 21st May 2012, 12:55 PM   #569
Thanks Salas
What caps did you have in the Mez ?
Poor caps would give poor results.
Old 21st May 2012, 01:10 PM   #570
weskoki's Avatar
Nichicon Muse and Elna I will try to hot rod it just to see if there's improvement.
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 13 17th May 2010 12:56 PM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
Copyright ©1999-2013 diyAudio
