#551 |
Salas thanks for your inspiration, i've found the problem and like always was an human error in the pcb design. Now my buffer sings very very nice and makes a nice team with the Simplistic Riaa
#552 |
diyAudio Chief Moderator
Excellent. Enjoy.
#553 |
After building and testing the DCB1 with plain resistors i want to buy some better quality resistors (mainly for buffer part) and i ask you what to choose (preferably from Mouser ).
What about CF1/4CT52R221G KOA Speer Carbon Film Resistors - Through Hole or these RN55C2200BRE6 Vishay/Dale Metal Film Resistors - Through Hole If you have some other sugestion i'm open to something else. |
#554 |
Snake oil territory - beware.
The Vishay RN55 are pretty good. |
#555 |
metal film, 1%, 25 or 50ppm/C, all copper connections (non iron, Fe) are very good.
0.1% and 15ppm are not worth paying the extra for unless the circuit specifically requires those. |
#556 |
I used DALE 1% Metal Films in the signal path.
There was much more improvement to made with the caps. I used Siemens 1.0uF MKP caps at the input and Oblligato 10uF PIOs at the output. Again, the difference is subtle and definite snake oil territory. You wont fit these caps on a Mesmorize board though. I used a homebrew clone of the original B1 board. The resistors at the bottom right of the board are not in the signal path so I just used good quality 1% metal films there. I can't find the original photo so I'll post it again - Apologies to the Moderators. I eventually used the Mesmorise board as a Salas shunt reg with my homebrew Pass B1 boards. Last edited by KatieandDad; 13th May 2012 at 11:38 AM. |
#557 |
Forgot to ask you if worth to buy some BL grade transistors if i have matched GR transistors with Idss around 5.5
#558 |
I used these
eBay - The UK's Online Marketplace Whether you will notice any difference is up to you. |
#559 |
Dimitris
Guys I am waiting for some mesmerize boards I got from the diyaudio store and I am currently planning on the rest of the parts.
What I was wondering is if there is a way to get two outputs from the board, so that I can drive 4 monoblock amps (dual - dual mono setup driving woofers and mid-twitters separately) Thanks a lot Dimitri |
#560 |
not politcally affiliated
I've listened to KOA Carbon Films and Dale CMF55, and prefer the Dales. The Carbon Films were too smooth for me.
There is very little in the signal path here, so resistors are about the only thing to change.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE |
| WTB Mezmerize PCB | 3GGG | Swap Meet | 3 | 16th January 2011 09:15 AM |
| FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed | korben69 | Swap Meet | 13 | 17th May 2010 12:56 PM |
| My XXLS Subwoofer building thread... | harrisni | Subwoofers | 9 | 28th October 2007 08:21 PM |
| Fave song from SOAD 'Mezmerize'? | PeteMcK | Music | 6 | 8th March 2006 03:12 AM |
| Gainclone building thread based on BrianGT's boards | meat | Chip Amps | 752 | 8th August 2004 06:25 AM |
