Mezmerize DCB1 Building Thread
Old 25th April 2012, 11:12 PM   #511
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Andreas, good, shows 160mA if with 10R set resistor then. You are welcome, we will read your further news.
Old 28th April 2012, 12:20 AM   #512
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
Default finished my DCB1
Finished my DCB1. Enclosure is a BUD box painted with a ceramic, semi-gloss engine paint from O'reillys. Knob is anodized champaign from parts-connexion. Heat sinks are from a local electronics salvage outfit. Internal wiring is 26awg silver 99.99% (not five 9s thank you ). Antek 50va shielded unit. Current resistors are MP930s mounted off-board on 220 heatsinks.Power switch is a switch/fuse/IEC combo.
If it looks overbuilt, it is. Haven't measured current but it is dissapating some real power. But, who cares, because it sounds great. Rail voltages are very close and offset is very low.
I was using a pot or direct out from my BDP-95 but the DCB1 is a sonic blockbuster in comparison. Which in reality, is just due to a much better impedence match and now we aren't "throwing volume away". In short, it's an amazing non-sounding sounding piece of audio equipment. I'm definitely hearing things in tracks I haven't heard before, and that saying a lot because I listen a lot, my wife wouldn't agree, though.
I'll probably do a Makore front and lid. The only problem that I have is some hum, so I need to fix that. Otherwise it's a winner and I'm not easy to please at all when it comes to audio gear.
Cheers!
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, DCB1, VHEX + USSA-5
Old 28th April 2012, 01:12 AM   #513
Salas's Avatar
Happy that you are happy.
Still this is a simpler one, a Hypno, not a Mez. Regarding your hum, see about dressing closer together and distancing those trafo wires a bit further from the unshielded signal runs. Rotate the toroid a bit. It may be beneficial if your hum ain't due to a system ground loop.
Old 28th April 2012, 02:44 AM   #514
ggetzoff's Avatar
C'mon, any DCB1 porn is good for this thread!
I'll try that. Need to see if I can measure AC anywhere in the case and maybe ground pot case.
Old 28th April 2012, 03:05 AM   #515
Salas's Avatar
No DCB1 porn gets class X rating if the photos aren't showing the LEDS alight though.
Old 28th April 2012, 01:36 PM   #516
ggetzoff's Avatar
The man wants X-Rated....heh heh, here you go.
Old 28th April 2012, 02:18 PM   #517
Salas's Avatar
That's the real McCoy! Excellent.
Old 28th April 2012, 03:09 PM   #518
ggetzoff's Avatar
I'm supremely impressed with the way the thing doesn't sonicaly subtract from the source. When it comes to audio, I'm like a nasty food critic, and man does this thing taste good.
Old 28th April 2012, 03:10 PM   #519
Salas's Avatar
Nice. Did it drop some hum with the AC wires dressing?
Old 28th April 2012, 03:17 PM   #520
ggetzoff's Avatar
It did, thanks. Right now my son is watching cartoons on that rig so I can't play with it. However, I've still got some probably unrelated amp hum that I need to deal with. I'm talking about very quit hum, but still, hum. I need to take my MM and look for AC in the enclosure (s).
Eventually, I'm going to attach a stepper motor to a stepped attenuator (a double entendre?) and have remote volume control. Otherwise it just need some woodworking and it'll be done.
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
