#411 |
diyAudio Chief Moderator
Use 9mA quad for the signal section if you got. Less THD than using 6mA.
#412 |
Thanks Salas,
What about the others ? If you had a choice, what would you chose ?
Marinos |
#413 |
i get .5/2.5mv dc does that seem wrong i read under 5mv is ok, .5 seems off the matched quad i bought are 9.15/9.15/9.15/9.13 ? and 10.2/10.7v for power supply anything else to test ?
#414 |
Are both your output offset voltages a negative value? i.e. did you measure +0.5mVdc or -0.5mVdc? Similarly did you measure +2.5mVdc or -2.5mVdc for the other channel?
#415 |
+10.9mVdc, -10.2mVdc -.5mVdc, -2.5mVdc
#416 |
#417 |
Would an Antek AS-1215 ( 2x15V, 100VA, 3.3A ) be acceptable for the Mezmerize? Going over the threads I've seen recommendations for anywhere from 12-15V, 30-100VA. I already have one, and was under the impression that only its size would be an issue. Its a bit chunky. This will be my first DIY build so just beginning to learn, needless to say.
#418 |
Acceptable. Can do no harm. Its just bad economy.
#419 | |
#420 |
Thank you much!
| WTB Mezmerize PCB | 3GGG | Swap Meet | 3 | 16th January 2011 09:15 AM |
| FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed | korben69 | Swap Meet | 13 | 17th May 2010 12:56 PM |
| My XXLS Subwoofer building thread... | harrisni | Subwoofers | 9 | 28th October 2007 08:21 PM |
| Fave song from SOAD 'Mezmerize'? | PeteMcK | Music | 6 | 8th March 2006 03:12 AM |
| Gainclone building thread based on BrianGT's boards | meat | Chip Amps | 752 | 8th August 2004 06:25 AM |
| Page generated in 0.14706 seconds (100.00% PHP - 0% MySQL) with 10 queries |
