#291 |
first guess: check the polarity of the caps
#292 | |
diyAudio Chief Moderator
#293 |
hi! ok i rebuild it....i change all mur120 and capacitors 4700 i measure the trafo alone and all numbers was like should be.....after all i run out for 2 hours stand alone the mezmerize and all temprature was ok....probably the problem was defective mur..... thank you salas! hope to cu again on avclub
#294 |
OK, I finally finished my Mesmerize Blue! For input selection I used a circuit I posted here earlier (thanks AndrewT for assistance), and an Antek xformer (50VA 12V) and Par-Metal chassis. I also got one of those Chinese $10 stepped attenuators, which is remarkably good!
I'm attaching a few pics here. I previously posted photos of the board powered up. When I built my push-button selector I had initially planned for the whole thing to fit behind the front panel, but I couldn't get the layout to fit, so I split it into 2 boards: sw3.jpg Here is the chassis pretty much wired up. I ran out of my favourite shielded wire, so have only wired 3 of 6 inputs so far. inside_w_vc.jpg And here is why I built it: last year I built a set of Linkwitz Pluto speakers, but it seemed to me that they were not sounding quite right, and that my "preamp" (pre-outs of an old Arcam integrated amp) was the reason (I don't think the TL072 liked driving long interconnects): w_pluto_2.jpg Finally: The sound! Yes, it makes a difference. Lows frequencies are definitely deeper and tighter, which is interesting because the Pluto eq/xover is AC coupled and has a built-in LF roll-off (15 Hz I think). More importantly, I had felt that the Plutos were missing some high-end "sparkle", which I attributed to some HF roll-off due to cable capacitance and a high-ish output impedance. The high end is back! I probably need to adjust the tweeters down a bit now. Salas, thanks so much for this design and all your help, and others here (notably St. Andrew) also for the freely offered assistance. This is definitely the best thing I have ever built! |
#295 |
You are welcome and congratulations for the build. Nice presentation post also.
#296 |
I noticed that a lot of posts to this topic and, especially, the Hypnotize Hot Rod thread, are about parts selection. I am very pleased with my Blue Mez build, and thought I would note some of my parts choices and reasons. Keep in mind that I am making NO claims that my selections are better or worse than any one else's, and there are a few choices I might re-think if I had to do it again, and some choices I made simply because the parts were "good enough" and "there".
I was lucky enough to find another user on this forum who was selling an unpopulated Blue Mezmerize board and 7 relays (12V) at a good price, so I didn't have to wait for a group-buy. I bought a Schaffner FN9222R-1-06 power entry module from Mouser, wired to an Antek 15Vx2 50VA transformer. If the 30VA unit was significantly cheaper or physically smaller I probably would have got that. For a volume control I used one of these: DACT Type 21 Stepped Attenuator / Volume 20K for PreAmp | eBay I hate that they call it a "DACT-type stepped attenuator", because of course it has nothing to do with Danish-made switches. It's a stepped attenuator that uses 1% tolerance SMD resistors, and it seems pretty OK for $10! I got 2 pairs of matched JFET's from one of the suppliers here, "Blues". The Mouser search page is unpredictable, and when I searched for 2SK170's (unmatched) it told me they were out of stock, so I did a little Googling around. I found a place called Audio Lab of Georgia which had a good selection of parts at decent prices and ordered some JFET's, MOSFET's , diodes, and 12V regulators from them. Unfortunately, while they had 2SK170's, for MOSFET's they had IRFP240's and IRFP9140's, so those are a bit un-matched for me. After I had placed the order I searched again on Mouser and saw they had rafts of the 2SK170's in stock... I'm glad to spread my business around, but when I have to pay shipping on every order... For the big 4700uF caps I used Panasonic EEU-FC1E472; when I had searched a few days earlier there were some higher-value caps with the same diameter and lead spacing, but when I ordered I couldn't find any low ESR, high temp (105C) caps with a higher capacitance. For the caps across the group of 5 LED's, I used Panasonic FR 820uF 35V (105C). For the regulator output caps I used Panasonic FM 100uF 50V. For current-setting resistors I used Vishay RN65's. These were 0.5W 0.1% tolerance parts. That close tolerance is probably silly for that application, but I had some vague idea in my head to keep currents balanced among the resistors, and equal on each rail (which won't happen), and I wanted a low noise, low TCR (25ppm) part. The only values I could find in the right range were 61.9 ohms. I used 3 of those per side, so a baby "hot-rod" at about 80mA per rail. Most of the resistors I used were IRC RC55's, tight tolerance, low noise, low tempco metal films, mostly 0.1% tolerance / 25ppm. Instead of 220R I use 221R because that was what was available; likewise 221K. I couldn't find 1M RC55's, but I found Vishay PTF651's at that value, again 0.1% tolerance and very low noise, and also only 5ppm tempco! An extravagance at over $2 per, but I only needed 2 of them. For 470R base-stopper resistors I used IRC carbon composition RC20's, 5% tolerance, no noise figures, but the only carbon comp resistors I could find that even specified a tempco (not impressive at 150ppm, but better than some carbon films at 300ppm). I think everything else was pretty much per the BOM, except my custom push-button switch. Oh, wire: I used some nice shielded wire I got a while ago from Apex Jr.Home Page, stranded silver-plated copper, teflon insulation, and I think $0.25/ft. Unfortunately I ran out after wiring the volume control, the outputs and 3 inputs. Not sure what I will use for the other 3 inputs, I am considering some old 10base2 ethernet coax I have lying around. For non-signal hook-ups I used non-shielded wire from the same source, also stranded silver-plated copper. For jacks I used Neutrik NYS367's from Mouser. That's all I can think of for now. Last edited by nezbleu; 5th May 2011 at 04:49 AM. |
#297 |
I assume there must've been discussion about the resistor choices for what's titled as "audio resistors" in the Mesmerize BOM, but didn't find that content in this thread..?
As well, not much about the wires either in this thread.
#298 |
I have built a mesmerize. As the delay relais comes in (and also a few seconds after powering off) I hear a "Oempf" noise in the speaker.
Is this normal ? |
#299 |
Yes with some amps if you have a black board or early blue. Or you can implement the T mod. Which is integral to last boards.
#300 |
I missed this GB. Does anyone have one Mezmerize DCB1 board they would be willing to sell?
Thanks, Rush |
| WTB Mezmerize PCB | 3GGG | Swap Meet | 3 | 16th January 2011 09:15 AM |
| FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed | korben69 | Swap Meet | 13 | 17th May 2010 12:56 PM |
| My XXLS Subwoofer building thread... | harrisni | Subwoofers | 9 | 28th October 2007 08:21 PM |
| Fave song from SOAD 'Mezmerize'? | PeteMcK | Music | 6 | 8th March 2006 03:12 AM |
| Gainclone building thread based on BrianGT's boards | meat | Chip Amps | 752 | 8th August 2004 06:25 AM |
