Mezmerize DCB1 Building Thread - Page 28 - diyAudio
Old 27th February 2011, 03:59 PM   #271
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by qusp View Post
awfully dry,
The dryness is first to go with the Auris in RevB. Expands and layers also. So the Buffalo can be keeping happy an F5 even without gain in the line pre as I gather from you guys. Convenient.
Old 27th February 2011, 04:51 PM   #272
qusp is offline qusp  Australia
qusp's Avatar
cool, well that would make it altogether more listenable, as that was my main complaint and brought a slight digitalis with it.
thats the plan, i'm planning running a pair of ackodacs with opc's d1 for sabre straight into an f5x and ajx using digital volume. i'll try out the balanced dcb1 on the cables to my workshop still, but for the main rig i think it should work well without it.
the project is gonna take me a little while, parts for ajx should be here this next couple of weeks, but still need to build the speakers. hopefully everything will be ready to warm the cockles of my soul and perhaps my actual terrestrial body in the southern hemisphere winter months
Old 27th February 2011, 10:55 PM   #273
ramallo is offline ramallo  Europe
ramallo's Avatar
Send a message via Skype™ to ramallo
Today I had some time free......
More at more level.
200kOhm
Crosstalk:
+6dBu (1,55V)
+12dBu (3,09V)
THD+N
+6dBu
+12dBu
Freq response
+6dBu
+12dBu
600 Ohm
THD+N
+6dBu
+12dBu
Freq response
+6dBu
+12dBu
Crosstalk:
+6dBu
+12dBu
Enjoy
Old 27th February 2011, 11:18 PM   #274
Salas's Avatar
It has 270 Ohm output impedance, you tortured the poor guy on 600 Ohm.
But on load it can handle stays cool enough for THD with level I see. Thanks for your extra time.
Old 28th February 2011, 09:22 AM   #275
It's not the output impedance of the DCB1 that is the issue when feeding a low impedance load.
It is the output current capability.
A 8mAIdss jFET biased to 8mA has a range of output currents of -7.9mApk to +7.9mApk.
The absolute maximum driving voltage from the jFET into a 600r+270r load is 6.87Vpk. Only 69% of this driving voltage is across the 600r load.
4.7Vpk across the 600r hits the absolute current limit. The amplifier current clips.
+12dBu is ~4.4Vpk. The circuit has been driven into current clipping.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th February 2011, 11:43 AM   #276
Salas's Avatar
+6dbu is 1.55VRMS, should have had the current for the low load? Still it shows the same trend as in +12dbu (3VRMS).
Old 28th February 2011, 12:19 PM   #277
Single ended amplifiers generate distortion as they approach clipping. It's probably this that valve/tube folk like.
That increase in distortion can be avoided by ensuring the clipping voltage or current is 10dB to 20dB above the maximum normal signal that can pass through the stage.
Expect great performance when Iout <0.7mA to 2mApk
Expect gradually increasing distortion when 2mA < Iout < 7mApk.
Don't expect the SE amp to perform at all well when Iout >7mApk, for an 8mA bias.
Most pre-amps and the voltage amp stages operate in SE ClassA. That's why I try to adopt a clipping to max signal overhead of ~+20dB.
+20dB on a CDP signal is 22Vac. I can't and haven't tried to achieve that. +10dB to +12dB is certainly achievable for CDP replay.
regards Andrew T.
Old 28th February 2011, 12:24 PM   #278
Salas's Avatar
Yes, that is the B1 likeable thumbprint in a sense. We have referred in the past also I think. A JFET + BJT cascode or a JLH compound would hold differently with level. B1 maybe ''enamours'' digital sources dynamically its my guess. Reminding of analogue sources peaks. I would call it bridged loaded above 3kOhm. Beyond 10kOhm its dynamic THD signature is milder non the less (as in high load charts, post#250).
Old 16th March 2011, 11:15 AM   #279
Out of 100pcs of 2SK170BLs I was able to pull these 2 strings for a balanced build:
7.05/7.03 - 7.09/7.08 - 7.14/7.14 - 7.26/7.26
or
8.08/7.94 - 8.05/8.05 - 8.21/8.22 - 8.36/8.38
Which set is more desirable? And am I right in thinking the closest value pairs should be chosen per board.
Old 16th March 2011, 11:23 AM   #280
Salas's Avatar
The 7ish set is tighter as a whole. But both sets are very good. Just don't mix the sets in any board, so to keep them tracking THD between phases alike. Use stepped fixed resistors pots, else the levels aren't going to match well, compromising CMRR.
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
Copyright 1999-2017 diyAudio
