Mezmerize DCB1 Building Thread
Old 27th February 2011, 01:59 AM   #251
udailey is offline udailey  United States
Passive Aggressive
Congratulations Salas! Confirmation that its as measures as good as it sounds. Really makes me want a Tek AM700 too.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 27th February 2011, 02:03 AM   #252
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
That's the fully constructed Mez thing passing signal through its layout and relays and Alps pot. Not some direct proto test board. Don't know the signal levels used or more details. For one thing the noise floor and hum levels on its PSUs is fine.
Old 27th February 2011, 02:26 AM   #253
ramallo is offline ramallo  Europe
ramallo's Avatar
The pot is a 20k Alps and the test level was a bit low -6dBu. I'll try to do more measurements with more level (up to +14dBu).
Suso
P.S. I tried before at +4dBu and the measures was very close.
Old 27th February 2011, 02:29 AM   #254
Salas's Avatar
Is the the load 600 Ohm as in dBu pro spec?
P.S. Most studio gear run at +4dBu so if it was OK for that level, its enough. Commercial is -10. Don't bother for more.
Old 27th February 2011, 02:33 AM   #255
ramallo's Avatar
200k load on the Tek (the choices are 150 Ohm-600 Ohm-200k).
Old 27th February 2011, 02:41 AM   #256
Salas's Avatar
Good. Because its unlikely someone will use a 600 Ohm amp here. Was the volume pot fully open?
edit: I wonder, did you ever stick the Mez in a pro studio monitoring system to listen a bit?
Old 27th February 2011, 02:49 AM   #257
ramallo's Avatar
Yes, fully open.
I choose 200k because I'm using an F5 and is near (half).
If you want a specific test, let me know, I'll try to do.
Edit :-): I have plans for do a dual DCB1 Hodrod on the same chassis (one for channel) (all symmetric) for control the studio monitoring. I'm very very impressed with the 200mA DCB1 sound. But in the new one I'll try to go to 500mA by using a power amp chassis (2 or 3 unit)
Old 27th February 2011, 02:56 AM   #258
Salas's Avatar
Your FFT tests are a fine gamut thanks. If you will ever run a tough subjective test like a live voice direct mic feed from an Avalon mic pre or Voxbox between a digital desk or Mez A/B, possibly with 3rd party sound engineers as participants, I will be glad to know the outcome.
Old 27th February 2011, 03:05 AM   #259
Salas's Avatar
Sounds like a hot plan. Good luck and let us know.
Old 27th February 2011, 10:25 AM   #260
chalkandtalk is offline chalkandtalk  United Kingdom
I have just put together an F5 - and I like it! What drew my attention to it was the simplicity of the circuit. My preamp has a lot of gain and my speakers are fairly efficient so there's more than ample volume.
Someone then recommended the DC B1, because the circuit is simple as the F5. Has anyone used a B1 with the F5? I'm a bit concerned that there won't be enough gain. It may mean that I go for new speakers.
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 07:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 10:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 09:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 04:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 07:25 AM
