Old 14th February 2011, 04:21 PM   #221
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by superluca71 View Post
Voltage drop: 2.18v and 2.24v
DC Offset 1.2mv and 2.2mv
Very well. You may listen to it. Post that picture to see how you assembled it if handy.
Old 14th February 2011, 06:17 PM   #222
20 v-
10 v+
just a burned led!
now i have -10,15v and +10,35v
I wonder if one Shunt LED was in back to front?
They are diodes but they fail with a very low reverse voltage.
20V in reverse across a LED might well "burn it".
Old 14th February 2011, 07:11 PM   #223
No it was mounted right way, maybe to much time on it with the solder iron...
Old 15th February 2011, 07:36 AM   #224
Default Some pictures
still something to mount...
x Salas & Andrew:
Do you think i can hot rod this , just to add little more gain?
and how?
Old 15th February 2011, 07:45 AM   #225
Salas's Avatar
Only if you had mounted the mosfets to the floor *see ramallo's a few pages back. Then you could use 10R 5W or 22R//22R 2W where your 68R//68R are now and achieve around 200mA CCS with your Vdrops. With the little sinks you got its dangerous. Hot rod achieves more robust sonics from the regs, not voltage gain by the way.
Old 15th February 2011, 07:47 AM   #226
Thanks a lot!
Old 17th February 2011, 06:48 PM   #227
Hey guys,
I've just powered up my Mesmerize for the first time and something seems wrong
One of led arrays won't light, it's the one containing 5 leds. The other side does light up however. I've been looking at pictures from your builds and from the looks of it I got all the parts oriented correctly (caps, transistors, leds).
I've measured the voltage drop accross 68R CCS resistors which is as follows:
- 5.2V accross the side that's working
- 2.3V accross the side that's not working
I guess that's not correct.
I'm using a 230V/2x12V 50VA tranny.
Do you guys have an idea of what might be wrong?
Cheers!
Erik
Old 17th February 2011, 07:03 PM   #228
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
do a diode test across the unlit LED.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE
Old 17th February 2011, 08:19 PM   #229
Thanks for your quick response!
All the individual leds in the array seem fine and the array seems to react similar to the one on the other side.
Is there anything more specific I should look for?
Cheers!
Erik
Old 17th February 2011, 08:22 PM   #230
Salas's Avatar
Maybe the Jfet under the array which pulls current through is dead? One array faces the other way than its opposite as a whole mind you. Also 5.2V across the 68//68R on the side that IS working is too much. Are the Mosfets the correct types in each position?
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 13 17th May 2010 12:56 PM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
Copyright ©1999-2013 diyAudio
