Mezmerize DCB1 Building Thread
Old 12th February 2011, 04:24 PM   #211
westers151 is offline westers151  United Kingdom
Hi
I've finally populated and wired up my pre amp and stuck it on my test board (a bit of MDF ). Here are the measurements I'm getting:
V+ = 9.17
V- = 9.58
Measurements across the two parallel 68R's are 1.9V and 1.7V (is that the CCS measurement?).
So far it all looks good, however I'm very suspiscious about my offset measurements as I'm getting some strange results. If I measure the offset just after I've powered on the pre amp then I get 1.7mV on the right channel and 0.0mV on the left channel. However, as I continue to take readings the right channel starts to drop, and the left channel starts to gain mV. After a minute or so the right channel stabalises at 0.4mV and the left channel at 0.3mV.
Should I be concerned about the jumping around of the DC offset? It doesn't feel right to me, and neither do the figures as they seem impossibly small.
Note: I currently don't have the pot wired to the board. Not sure that would make a big difference.
Old 12th February 2011, 05:02 PM   #212
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Your measurements look fine. JFETs do warm up, so offset takes a while. Its not impossible small by the way, we got many such low references in the building threads. 1.9 & 1.7 are the CCS, yes. It got quite near in your case. Hook it up and let us know.
Old 12th February 2011, 05:04 PM   #213
Thanks Salas, that's reasurred me.
Tomorrow I will connect the pot and RCA's and then take her on her maiden voyage.
Old 12th February 2011, 05:09 PM   #214
Salas's Avatar
I am pretty confident you will see the Titanic sail back into Southampton.
Old 12th February 2011, 05:52 PM   #215
Old 14th February 2011, 06:32 AM   #216
superluca71 is offline superluca71  Italy
Default strange measurement
hi all,
at last i finished to assemble my mesmerize, supplied with a 2x15 30va trafo...
...warmed it up and took the measurement from the three pads in the middle of pbc:
20 v-
10 v+
very disappointed....
later i'll post some picture...
Old 14th February 2011, 07:02 AM   #217
Salas's Avatar
Troubleshoot it. -20Vout is obviously wrong. A picture will help, maybe we can spot something too.
Old 14th February 2011, 01:01 PM   #218
just a burned led!
now i have -10,15v and +10,35v
Old 14th February 2011, 01:07 PM   #219
Salas's Avatar
Its nice nothing else went too. Check DC offset on audio outputs and voltage drops across the 68R resistors also.
Old 14th February 2011, 01:15 PM   #220
Voltage drop: 2.18v and 2.24v
DC Offset 1.2mv and 2.2mv
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
