Mezmerize DCB1 Building Thread - Page 143 - diyAudio
Old 24th August 2014, 01:16 PM   #1421
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by SjoerdSmits View Post
How do I go to 200Ma??
Easy, 10 Ohm 2W total or individual resistance where says 2X68R. Both sides. And sinking the MOSFETS.
Old 24th August 2014, 04:13 PM   #1422
SjoerdSmits's Avatar
That is really easy :-)
Old 25th August 2014, 07:16 PM   #1423
KonPeki is offline KonPeki  Germany
I have a little problem with my relays (G6H-2-100 5V).
The input relay clicks, but the output relay doesn`t working and I cannot find any faults.
Does anyone have an idea?
Old 25th August 2014, 08:23 PM   #1424
Salas's Avatar
What voltage can you measure across the diodes near the working input relay and the output one?
Old 25th August 2014, 08:36 PM   #1425
Diode input relay: 6.68V
Diode output: 0V
Old 25th August 2014, 08:59 PM   #1426
Salas's Avatar
Problem. Change the BC 550 in the relay area first and make sure of orientations. Have you got BC550 and BC517 types there?
Old 25th August 2014, 09:33 PM   #1427
Salas's Avatar
Or use a 4.7V Zener B to E (cath) in the 550's place.
Old 25th August 2014, 09:57 PM   #1428
I changed the transistor (BC550B) . But the problem still exists.
Maybe my transistors are defective.
Tomorrow I will try the Zener diode. This idea sounds good.
Thank you Salas.
Old 25th August 2014, 10:19 PM   #1429
Salas's Avatar
V EBO is 5VDC in the datasheet but if its higher in a batch or manufacturer then it will not do it for 5V relays. Although it always used to in the past 5V builds. Get a 4.3V 0.5W Zener too.
Old 27th August 2014, 09:00 PM   #1430
Okay, it works now.
Measurements are:
Offset: L= -3.7 mV; R= -3.8V mV
Current set resistors (22R||22R): 1,6V/1.75V
10.47V; -9.85V
I hope, this is okay.
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
Copyright 1999-2017 diyAudio
