Mezmerize DCB1 Building Thread
Old 9th February 2014, 06:54 PM   #1181
WalterW is offline WalterW  Netherlands
That's the schematic I have too, if somebody has a better one, pls post...
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 9th February 2014, 06:58 PM   #1182
Turbon is offline Turbon  Sweden
Turbon's Avatar
The components are in the same positions so the schema should do for debugging.
But of course the correct schema would be welcome.
Old 9th February 2014, 07:02 PM   #1183
McQuaide is offline McQuaide  United States
Here's the one I have.
https://dl.dropboxusercontent.com/u/...-schematic.png
Old 10th February 2014, 07:27 AM   #1184
Turbon's Avatar
Originally Posted by McQuaide View Post
Seems to be the same when it comes to the positive rail. I haven't checked the rest. Neither have I checked if Andrews claim is correct that there should be errors in the schema - it is usable anyway.
Old 10th February 2014, 09:31 AM   #1185
R.I.P.
If my comment in post1179 is wrong then tell me and tell the other Members.
regards Andrew T.
Old 10th February 2014, 10:01 AM   #1186
Turbon's Avatar
Andrew, the arrows in Q1 and Q2 should be pointing downwards so you were quite right. Now I didn't give the fact much attention since I put it right in my mind and thought.
Since the actual components are FET's the symbols are wrong as well BUT they can be useful for describing the function as is.
BUT my call for help took a totally different direction...
Old 10th February 2014, 10:26 AM   #1187
mrWagner is offline mrWagner  Hungary
This schematic is also what Salas posted in another topic. I also built my board by that, so it should be fine. You should check each wire from the board setup to see if really all the components are facing the right way and all wires conenct to the right components.
PS: I guess the system doesn't work well with 1 side partially dead. You'll have to find the dead component, replace and then go on.
R13 has 0,168V dropping, meaning ~17mA if you used 10R. If T6 is a 2sk170, than it is dead for sure (12mA is max for BL).
Old 10th February 2014, 10:33 AM   #1188
Turbon's Avatar
Thanks mrWagner.
It worked allright for days +9.86V -9.79V but I believe I shorted something poking around measuring. So everything are where they are supposed to be.
V+ still rising... When I first took a reading after the short it was 12.5ish but last evening it was 16.5ish... Very strange.
I have ordered spares.
Old 10th February 2014, 10:51 AM   #1189
KatieandDad is online now KatieandDad  United Kingdom
KatieandDad's Avatar
I did as Salas suggested and measured each chain of LEDs with the FET that was going to be used with them on the breadboard.
Old 10th February 2014, 10:56 AM   #1190
Turbon's Avatar
KD, yes I will probably need to redo that when I have replaced, as I believe, Q2 and got it working again. That is another issue.
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
