Mezmerize DCB1 Building Thread
Old 3rd December 2013, 10:14 AM   #1101
R.I.P.
Many will find that any "pre-amp" that has an optional +6dB, +12dB gain useful for those Sources that are relatively low output.
And most will find they rarely need to use anything other than +0dB of extra gain.
regards Andrew T.
Old 3rd December 2013, 10:21 AM   #1102
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I have in mind to investigate on such a versatile pre. Say having a DCB1 plus a good simple circuit cell with gain on same pcb. A relay to choose which one is employed etc. But a cell with gain that will still resemble the DCB1 when in action is a difficult find. Will see.
Old 3rd December 2013, 05:56 PM   #1103
Renron is offline Renron  United States
Renron's Avatar
Salas,
I have already built the Preamp you are looking for. It is a combination of the DCB1 (mez) and the "Super Simple Preamp" . I have a switch which can include or exclude the "SSP" which will add gain if needed (not often) to the chosen recording. Gain can be changed with different resistors. I have not noticed any denigration in sound, although some may argue against having the "chips" in the circuit. (hence the switch) This pre is in front of my F5 and it sounds fantastic on quality recordings. Not forgiving of poor recordings though.
SSP link: DIY Simple Active Preamp - Page 17 - AudioKarma.org Home Audio Stereo Discussion Forums
Post #248
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 11th December 2013, 10:24 AM   #1104
auxie22 is offline auxie22  Australia
I will be modding a marantz CD-53 and one of the mods boosts output gain so I believe I should be ok also plan on using it all with PMC Db1i clones which I think should have roughly 90-92db SPL once done.
Old 30th December 2013, 11:07 PM   #1105
delecoy is offline delecoy  United States
delecoy's Avatar
Finished my mesmerize with 10R hotrod. Have it playing on the burner stereo. Nothing has burst into flames yet. What else I should check before hooking it up to the big stereo?
Old 30th December 2013, 11:15 PM   #1106
Salas's Avatar
Very little DC offset on both its audio outputs should indicate its safe to hook up on the better gear.
Old 30th December 2013, 11:29 PM   #1107
delecoy's Avatar
With the voltmeter set to 200m measured from ground to left then ground to right on the outputs and got 1.0 and .8 respectively.
Old 30th December 2013, 11:32 PM   #1108
Salas's Avatar
Virtually nil then. Alright, if you can hear the relays clicking on and off as they are supposed to also, there is no danger. Just know there is no DC from a source it can pass to a DC coupled power amp.
Old 30th December 2013, 11:43 PM   #1109
delecoy's Avatar
Excellent. It'll be going into a GFA-535....in the next ten minutes. Have heard the relays clicking on and off. Thank you for a wonderful project . Should mention now, the DCB1 will be used with the aforementioned GFA-535 ( which I believe is DC coupled ) and a SCHIIT bifrist DAC that is for sure DC coupled. Should I take precautions of some kind?
Old 30th December 2013, 11:49 PM   #1110
BigE is offline BigE  Canada
BigE's Avatar
measure DC output when the DAC is attached, but dcb1 not connected to the amp.
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
