Mezmerize DCB1 Building Thread
Old 19th November 2013, 12:53 PM   #1081
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Take the chassis to IEC mains grounding wire away from the toroidal's screw. Use a dedicated chassis mounting point for it. 50VA toroid will be fine for your setting while 80VA will be rich enough if you feel like overspecifying it.
How you can measure output offset if the output relay makes no contact for instance? Impossible. Maybe you used latching type relays? Correct type is Ea2-12NJ
Old 19th November 2013, 01:02 PM   #1082
Salas's Avatar
Also make continuity tests in case you switch in some other input from the one you expect by some mistake in the control switch's wiring. Or it does not allow to engage at all for some reason.
Old 19th November 2013, 01:55 PM   #1083
submat50 is offline submat50  Slovenia
Thanks, Salas.
I have NEC EA2-12NU. It is non latch tipe, but leg 1 is + , like in the picture.
1 2 3 4 5
10 9 8 7 6
Is it true, that on the bord for this configuration of pins, leg 10 is + .
matjaž
Old 19th November 2013, 03:29 PM   #1084
Salas's Avatar
By top view the board is having the +mark on pin 1.
Old 19th November 2013, 04:00 PM   #1085
Salas's Avatar
Did you jumper the "note" pads by the way? Can you find about +12V on pin 1 of the input relays? Are the diodes next to them correctly orientated?
Old 19th November 2013, 07:20 PM   #1086
Salas thank you for your coatching. I just found the mistake. I did not solder one pin in the input relay. Output relay is working properly so that the offset is just that i wrote. Must i make some rekonfiguration of jfets.
At first sight DCB1 is a hugh difference versus my old preamplifier. Tomorrow I will better describe my opinion.
Salas, thank you.
Old 19th November 2013, 08:07 PM   #1087
Salas's Avatar
Well done.
Old 21st November 2013, 03:09 AM   #1088
Opinion, which I promised. My system now consists of:
Mac mini with iPad Remote
Arcam RDac
DCB1 before Valve Preamplifier
MiniDSP
One chanel 2x monoblocs Pass F5 (total 4 x monoblocs F5 and 2x monoblocs Zen V4)
OB, U and H frame (15 kombination)
Gaina is just enough (i have 20k potentiometer, which is completley open, I think to cahange it for resistors but I need DCB1 also for phono)
The sound has a better resolution, a better stage and better bass. I think I've come up with DCB1 to the end of my DIY boundaries.
Matjaž
Old 21st November 2013, 03:32 AM   #1089
Salas's Avatar
Congratulations.
Old 27th November 2013, 10:42 PM   #1090
auxie22 is offline auxie22  Australia
I plan on building the B1 and the Aleph J and possibly eventually the F5 I found what looks to be legitimate matched 2SK170 GR's from ebay.
http://www.ebay.com.au/usr/lady.twilight
I might buy some and do testing seems pretty cheap too
by the way better to copy the link and paste it into your browser
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
