Mezmerize DCB1 Building Thread
Old 30th August 2013, 05:08 AM   #1021
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by JOHNNYCR100 View Post
cheers Gents
Johnny
Post a close enough clear photo so we may spot what's wrong. You probably shorted them MOSFETs backs.
Old 30th August 2013, 09:54 AM   #1022
R.I.P.
The two main "pass" mosFETs do not dissipate maximum power at the same time.
This makes it economic for the two to share a heatsink. see below.
But both must be electrically isolated form the Chassis.
Worst case 1.
If the output is shorted, the CCS FET passes normal current but drops the whole supply voltage. CCS is at max dissipation and the Shunt FET has zero dissipation.
Worst case 2.
When output is open circuit, the Shunt FET is at max dissipation. Now the TOTAL dissipation of both FETs is the same as the worst case in the shorted condition. The same size heatsink will have the same power input.
Nortmal case.
When operating normally the total heatsink dissipation is less than the two worst cases above and the FETs will run cooler.
regards Andrew T.
Old 30th August 2013, 10:08 AM   #1023
JOHNNYCR100 is offline JOHNNYCR100  Abu Dhabi
Default my Hot Mosfets
Thanks gents,
I will post a picture when i can get my hands on my camera - strange to relate all the voltages are " ball park" and the DC offset is also OK (low- 5 mv / 1 mv) but its to hot (well one side is) , I will read posts and digest- get back soon, thanks boys.
Johnny
Old 30th August 2013, 10:12 AM   #1024
Default and
PS The mosfets that get hot each have there own heat sink and not joined to anything else.
Old 30th August 2013, 10:35 AM   #1025
R.I.P.
This makes it economic for the two to share a heatsink. See below.
But both must be electrically isolated from the Chassis.
Worst case 1.
If the output is shorted, the CCS mosFET passes normal current, but drops the whole supply voltage. CCS is at max dissipation and the Shunt mosFET has zero dissipation.
Worst case 2.
When output is open circuit, the Shunt mosFET is at max dissipation. Now the TOTAL dissipation of both mosFETs is the same as in the worst case 1 (the shorted condition). The same size heatsink will have the same power input.
Normal case.
repost with errors corrected.
regards Andrew T.
Old 30th August 2013, 12:23 PM   #1026
McQuaide is offline McQuaide  United States
Mine is cool to the touch as well. Sounds like there is a problem somewhere.
Old 13th September 2013, 01:48 PM   #1027
Gooch is offline Gooch  United States
Gooch's Avatar
I am about finished with making my chassis and ready to start stuffing the PCB
I only need 2 inputs so will there be a problem with using only two relays and leaving the other spots just empty. It looks like the single path tones out with my DMM with out the use of jumpers is this correct.
Thanks Dave
Old 13th September 2013, 01:53 PM   #1028
Eric is offline Eric  United States
Eric's Avatar
If you only need two inputs, then only use two relays... No harm in leaving the rest empty. I have need for 2-3 inputs, so I installed only 4 relays and diodes.
I'm not exactly clear what you asking in your second question.
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 13th September 2013, 02:06 PM   #1029
I used three inputs and left off the relays and diodes for the other three. No jumpers are needed.
Old 13th September 2013, 03:57 PM   #1030
Gooch's Avatar
Default Mezmerize DCB1 Building Thread
Thanks guys appreciate it hope to have sweet music soon
Sent from my iPhone using Tapatalk - now Free
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
