i'm a newbie here. and my system is x2.5 + x150 + b&w m801s2.
i have a chance to upgrade to x250 or x350. do you think it's a must or a good idea for my m801s2? it's said that x150 has the best sonic purity and is the most transparent. my m801s2 is very revealing so that i'm afraid x250/350 will sound harsher than x150. any analysis between will be very appreciated. btw, it seems x350/600/1000 are slightly different from x150/250 in terms of spec such as damping factor. x150/250 has a damping factor at 250 while x350/600/1000 at 30. it's very strange too for me that x350 has 26db gain in contrast to 30db for x150/250/600/1000. |
#2 |
seems not a good topic here.
nobody gave comments |
#3 |
This is more or less a DIY forum where it is unlikely that the majority of the members have had the pleasure of evaluating even one of the aforementioened amps.
My take on this is that you should: 1. Ideally take the new unit home to sample, then make the decision. 2. Since you have a balanced source, there is no reason why you should not be able to move. As you know, the smaller X units accept single ended more readily as I recall. 3. I am personally not a favourite of very high wattage units, but if you do go to a higher wattage, you will also get more output devices, better power supply etc. You will also get a different input stage (at least for the 350) which probably operates at significantly higher current and is thus capable of driving the output stage better (to the best of my knowledge anyhow). 4. If you get stuck, contact the factory for support. I am pretty sure they will tell you that the larger units behave better. My personal feeling is that I don't like the aestetics of the 150. If money is no object, you simply have to move to the larger units. Petter |
#4 |
The one and only
Petter is right. You have to try the amps out in your system
to find out. It seems that for most designs, there is a "sweet spot" for size and bias, etc. For the X series, that would be the X600 in my opinion. For the Alephs, it would be the Aleph 2. It remains to be seen for the XA and the Zens.
#5 |
Is this 'sweet spot' due to the human being's natural
craving for more amplifier power
#6 |
The one and only
Not usually, otherwise the X1000 would represent the Pass
Labs sweet spot. |
#7 |
But it requires a fork lift, dedicated electrical panel, and 2 extra tons of A/C.
#8 |
The one and only
Actually it only draws an extra 150 watts or so.
#9 |
thx all you guys. especially nelson.
i'll try it in my house. thx for your remind that here is a diy forum. so let's go back to technical aspects of x series. according to nelson, the sweet spot of x series circuitry corresponds to x600. how far apart are x350 or x250, in term of any technical merit. btw, i saw many people on net waiting for nelson's baby x600 or mono-mono x250/350. |
#10 |
To my knowledge (looking at photographs), the 250 is the top of the line for the "smaller units", a series which came after the larger units. It appears unlikely that this circuitry will be as effective driving the larger units but that is pure speculation. Thus, the 250 maxes out the lower line. The slightly different topology, or at least part choice may explain the different specifications which you have already pointed out.
The 350 is the smallest of the big boys (the original series). There appears to be precious little that puts this unit apart from it's even bigger brothers, apart from power supply and number of output devices. Then again, it might just be that the new unit is "better", and the old line simply remained unchanged. I doubt it, however. As you might expect from the above, it appears like the smaller and larger lines are two branches of similar technology - and each line has a common theme (the input stage) and differ mostly by size of power supply, number of transistors etc. At the end of the day, I am glad that you have the opportunity to check these units in your home and hope that you will post your results back to this forum. Good luck. Petter |
| X150.5 manual ? | barti | Pass Labs | 6 | 1st November 2009 04:10 PM |
| 12V Trigger for X150.5 | rc5al | Pass Labs | 8 | 15th December 2008 05:12 PM |
| pass x150.5 | barti | Pass Labs | 2 | 18th October 2008 04:03 PM |
| X150 amplifier compatibility | Heiney9 | Pass Labs | 8 | 1st October 2007 09:21 PM |
| PassLabs X150.5 in Hiraga's Nouvelle Revue Du Son | CheffDeGaar | Pass Labs | 10 | 10th November 2005 04:16 AM |
| Page generated in 0.10372 seconds (83.59% PHP - 16.41% MySQL) with 10 queries |
