Hello all,
Just picked up a Threshold 400A amp. Would like some input on restoration. 1) Will definately replace all the caps. A question arises about the resistors. Should they be replaced as well? 2) Looking for advice on the output transistors? Do they really need to be replaced? I didn't think they wear out. 3) Bias setup: Does anyone have a good procedure to perform? 4) Any idea where I can get a power switch or handles? The unit looks good for it's age, but the handles are missing. Thanks in advance! |
#2 |
Forgot to post pics:
#3 |
Rang Jon S. at vintageamp repair today. Hoo-Boy! I've got to wait and pop the top cover off to see what version of 400A it is. It may or may not have the cascoded mod done. Hmmm...
#4 |
Well the unit arrived today. I think it's a non-stasis, but not sure what driver board is in it. Here is a pic of the board, and the output devices:
what does it look like to the boffins out there? |
#5 | |
2.if amp is working OK - there is no need ; inspect carefully condition of white thermal goo around outputs ; if needed - you must renew that ; dismantle ( one by one ) every output , clean transistor, mica , heatsink and grease again 3. search in forum - it's published several times ; I'll attach that again , but I don't have it in tis comp 4. someone will chip in ....... I dunno
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#6 | |
I did search the forums, and I did find one that looks promising, BUT, it's missing the first three steps. IF one decides to replace the output devices, do you use the same, or look for a sub? I wonder if a sub would change the character/behaivor of the amp? |
#7 |
why to replace them , if they are functional ?
#8 |
#9 |
An excellent question! I was initially thinking that as well. However, I've been advised by former Threshold techs that the old aluminum cans have been overly stressed over time, and could easily fail. My buddy (who's also a outstanding tech), thinks cleaning up the mounting of the existing devices should be performed instead. He told me he has good individual pads for them. Thanks so much for the data. It looks like the same stuff I found here on DIY (Pretty sure you posted it before, much thanks!) If you look at the bias procedure, it starts on step 4, so I don't know what the first three steps were. Do you remember what they were? |
#10 | |
![]() I don't have that - missing - page , but I think that you have more than enough information later in document
| Threshold 400A HELP !! | Airedale | Pass Labs | 2 | 16th February 2005 10:56 PM |
| Threshold 400A | Airedale | Pass Labs | 2 | 17th January 2005 10:57 PM |
| Threshold 400A | johnsciolino | Pass Labs | 1 | 29th August 2004 06:50 PM |
| Threshold 400a advice needed. | harhaug | Pass Labs | 11 | 16th June 2004 07:43 AM |
| Page generated in 0.11797 seconds (82.54% PHP - 17.46% MySQL) with 11 queries |
