Old 11th July 2003, 01:54 AM   #1
lawbadman's Avatar
Default Bosoz
Hi all
I am in the middle of building a bosoz pre amp, but I will only be using the + input and + output. My question is if the following parts are necessary for my application:
C1, R9, R11, R8, and R14.
Old 11th July 2003, 02:05 AM   #2
macka's Avatar
lawbadman,
You will find details of the single ended operation in the original article.. http://www.passdiy.com/pdf/balzenpre.pdf
macka
Old 11th July 2003, 02:55 AM   #3
eLarson is online now eLarson  United States
eLarson's Avatar
Default Re: Bosoz
Originally posted by lawbadman
Hi all
You don't need C1, R9, and R11 for sure.
I left R8 and R14 on mine. I ended
up installing a balanced input on mine. Son of
Zen's bride does good work as a
balanced-to-single-ended converter.
Erik
Would a woodchuck bother to chuck MDF?
Old 11th July 2003, 05:50 AM   #4
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Just build it per the article. Short the negative input to ground.
then enjoy
Then when you want to use it as a unbalanced to balanced
converter (to run, say an Aleph 2) you're all set. I've run mine
unbalanced into an Aleph 3 for a while now and it sounds great.
Old 11th July 2003, 04:23 PM   #5
lawbadman's Avatar
Thanks for the info guys.
I left out C1, R9, R11 and R8.
Has anyone done any modifications to the power supply for better sonics?
Old 14th July 2003, 03:10 AM   #6
eLarson's Avatar
I made a minor adjustment by using a
choke-input filter after the rectifiers.
I can't say for sure that it made a colossal
improvent, but the basic quality of the
remaining crud was more of a hum than a buzz.
I suppose the hum would have driven me
crazy(*) more slowly than a buzz would, but I
still couldn't tolerate it. Therefore I ended up
adding the zener/source-follower
"regulator" from the article (lower voltage,
though, naturally).
Now it is plenty quiet enough for my listening
room where the ambient noise level is rather
higher than I'd like.
Erik
(* Okay, it's not a drive; it's more of a short,
leisurely stroll. )
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 04:15 PM
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 2 24th December 2004 08:50 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 01:55 AM
10K Pot for the BOSOZ raincheck Pass Labs 13 20th September 2002 07:22 PM
Page generated in 0.09102 seconds (73.91% PHP - 26.09% MySQL) with 11 queries
