#31 |
#32 | ||
#33 |
#34 |
The one and only
You have to do a lot of testing to assure perfect matching, and
this is not usually practical. That's why there are ballast resistors on the Source pins - to improve the equality of behavior. For Mosfets I simply test Vgs under typical idle conditions and use parts from the same lot code. In actual output stages with lots of parallel devices this works fine.
#35 |
Nelson, you are 100% right.
When I bought 20 IRFP240s from mouser I got maximum Vgs difference 6mV at 1-1.5A Iq. It means that the transistors manufactured under same conditions (some equipment, timestamp, etc) are very very close to each other and do not require an extra effort to match them. Last edited by frags; 8th December 2010 at 05:13 PM. |
#36 | |
Audio Junkie
For a conventional amp i agree but what about matching for rail switches where there are no source/drain resistors?
It's not about what you can BUY...It's about what you can BUILD! |
#37 |
#38 |
Bksabath,
Here is the schematic for differential FET testing You need to measure the voltage difference between FET drains which should be zero in case of two absolutely equal FETs. With the potentiometer you can set desire current via FETs. R5 and D1 for FET gate protection and can be omitted. Temperature drift will equally affect both FETs if are they mounted at the same heat sink. Again, you need to match R1 and R2 as close as you can. Last edited by frags; 9th December 2010 at 03:42 AM. |
#39 |
Frags,
I can't open your link, not even in a new window. |
#40 |
Hi Frags
Sorry Mate The link does not work Al |
| Testing a Mosfet | vdi_nenna | Pass Labs | 3 | 2nd February 2010 08:21 PM |
| BiCMOS Bipolar+MOSFET better than MOSFET | lineup | Solid State | 5 | 8th December 2009 11:46 AM |
| testing, testing 123 | neil_kaye | Full Range | 0 | 25th December 2005 08:21 PM |
| MOSFET/MOSFET amplifier | jarek | Pass Labs | 21 | 22nd June 2004 05:04 PM |
