#101 |
#102 |
it is time to build the other channel. so you can switch
#103 |
#104 |
RIP
It is hard to help with out the schematic you are using and where you are taking voltage measurements.
What are your source resistor drops. Is the DC offset plus or minus. Who's PCBs are you using, have they been proven. |
#105 |
Which end of the zener connects to the positive rail? Should be the cathode (band)
What is the resistance from the zener anode to ground or negative rail, depending on which you use? What is the voltage between the CCS mosfet Source and the positive rail? We're trying to be sure the CCS is working before we worry about the differential pair. Measure the voltage referenced to ground at both ends of the zener, all three pins of the CCS IRF9610 Last edited by BobEllis; 29th October 2010 at 10:24 PM. |
#106 | |
#107 | |
#108 |
OK, I have no idea what you measured, but lets start here:
What is the voltage across R13? This should be rail-9.1. What is the voltage across R14? Should be ~4V What is the voltage to ground at Q1 and Q2 source pins? Should be ~4V |
#109 |
RIP
Well, I can tell you that your board is not a BrianGT board.
Bob, if you're using the manual can you email it to me. That's one I don't have. |
#110 |
Bill, I'm just working off the board image and imagining the schematic.
Not Brian's latest board, but may be an early version. |
| FE138ES-R - Dave, your dream came true... | blumenco | Full Range | 522 | 10th April 2013 12:50 AM |
