#21 |
Maths and I are not lovers thats for sure ! I spent my teenage years on your side of the Atlantic where the pot was plentiful and cheep...and the girls loved my accent..... Boy, I regret it now .
I found a parts list here on the site with the Digikey stock number on it . Digikey use the same stock number here in their UK ..... I'm hoping my heat sinks are big enough to expand some day, especially as the top and bottom plate will be made from (anodised) 3mm St Steel . and the rear panel 2mm copper . I have those heat sinks from my little hick up . I could use one for the front plate . its looking kind of cool also . I have also found a recipe for a thermal epoxy home brew . I have all kinds of metallic powders I can use , but bronze seems to be the best option , So 1:1 ratio ( mix ) join the side sinks to the front one and I'll be able to store ice cream in it . Rich |
#22 |
Gents,
I got my Digikey order this morning and thought it would be a good idea to read what each item does within the circuit as I populate the boards. TIA |
#23 |
are there any notes on the above topic that could help ?
#24 | |
Russellc |
#25 |
#26 |
Thank you Russell ,
I have the grease . I used the epoxy to join the heatsinks together ... The zxt 450 I ordered have different lead dimensions than my PCB ... are they useless ? I was full of confidence. This is going to be a lot more difficult than I thought ... Rich |
#27 |
slide a tube insulator over the middle leg of the ZTX. Look carefully at the ZTX datasheet and determine which leg goes into which hole of the PCB. Form the legs into the arrangement needed and drop it in. Check you have no shorts even if the transistor body gets abused/moved at some time in the future. Solder it in place.
regards Andrew T. |
#28 |
Hi Rich,
from your first post I assume that you are building an Aleph 30. I don't know whether a construction guide for this amp is available. But anyway, I have some hopefully useful links for you: For help in the correct identification of the ZTX legs (also in comparison to equivalent parts) and general assembly hints see cviller's F5 guide: http://viller.eu/audio/2009jan_gbf5/gbf5_guide.pdf You might also have a look at this F1 assembly guide for getting an overview on how to organize the building process: F1 DIY Amp Hope this helps Last edited by heinz1; 15th October 2010 at 02:21 AM. |
#29 | |
Here's a pic of some fets I got from member Blues, another shot of them beside the tiny Paul Daniels boards for the F-5, and finally a closeup of the pad on the Daniels board. Hope this helps. |
#30 |
Whoops, that's for the F-5. I'm also building an Aleph mini. If it really trips my trigger, I've got the boards for the 30 or 60. doesnt appear any worse than the F-5, plenty of support here.
Russellc |
| Complete tube amp novice got a few questions!! | Boscoe | Tubes / Valves | 22 | 22nd August 2010 04:52 PM |
| Could anyone help a novice? | sunnycue | Full Range | 8 | 4th August 2006 05:45 AM |
| Novice in need of help | skiermurph | Solid State | 2 | 22nd December 2004 01:52 AM |
| Tweakable Turntable For Complete Novice? | NattyDread | Analogue Source | 0 | 10th June 2004 06:46 PM |
| Page generated in 0.12438 seconds (81.83% PHP - 18.17% MySQL) with 11 queries |
