Complete Novice Needs Help - Page 11 - diyAudio
Old 18th November 2010, 04:10 PM   #101
richluvsound's Avatar
Farnell have them .... 20 quid min charge if I buy through the website and 30 quid to use the phone order line ..... No thanks . Digikey has no minimum charge and 12 pound shipping .... I was going to wait and see if I need to replace anything else before I ordered.
Im off work waiting for a double hip replacement ... every penny counts
readings ...
Old 18th November 2010, 04:23 PM   #102
RIP
Hips, ouch.
I see the 62v, do you have 31 to ground at the amp boards?
I don't know what a quid is.
Old 18th November 2010, 04:34 PM   #103
Right Channel
25 V + to Ground = 30.35
25 V - to Ground = 32.35
Left Channel
25 V + to ground = 32.26
25 V - to ground = 30.45
Rich
Old 18th November 2010, 04:38 PM   #104
RIP
OK, check to see if your offset is plus or minus so we can tell which half of the amps aren't working. It looks like it will be minus.
Old 18th November 2010, 04:40 PM   #105
Sorry Bill , I dont know how to do that
could you explain ?
R
Old 18th November 2010, 04:42 PM   #106
RIP
Just put your meter across the output terminals, black to black and red to red.
Old 18th November 2010, 04:46 PM   #107
0.814 r-r
1.002 b-b
Old 18th November 2010, 04:52 PM   #108
RIP
I think you misunderstood. We are looking for DC at the output of each amp where a spkr would be hooked up, that is the offset. The amp is supposed to be balanced so that there is only millivolts at the spkr hookup. If one set of fets is turned off, as you have, the offset will be very high.
Old 18th November 2010, 05:00 PM   #109
my meter reads .818 r-r v not mv
b -b is 1.001
Old 18th November 2010, 05:06 PM   #110
Default like this ?
I took the first measurement from the amp board out put
Complete tube amp novice got a few questions!! Boscoe Tubes / Valves 22 22nd August 2010 05:52 PM
Could anyone help a novice? sunnycue Full Range 8 4th August 2006 06:45 AM
Novice in need of help skiermurph Solid State 2 22nd December 2004 02:52 AM
Tweakable Turntable For Complete Novice? NattyDread Analogue Source 0 10th June 2004 07:46 PM
Copyright 1999-2017 diyAudio
